Engel Tie-Down
  • Engel Tie-Down
    Hi,
    I have Just Picked up my 04 Diesel GXL and am going away in 2 Weeks.
    I haven’t got the Time to make a Rear storage System for it at the moment but I need to hold the Engel down for the Trip. I have a Fridge Slide and was thinking of Fixing that to a piece of Marine Ply or MDF then bolting that to the Floor using the Bolt holes that the Tie-down loops use? Am I doing the right thing or has any one got any other suggestions or Ideas? I’d prefer not to have to drill any extra holes just yet!
    Thanks In advance
    Matt (WA)
    265/70/R17 Cooper ST's, 2" Lift OME Springs and Shocks. GME TX3400, Mattified Kaymar Rear Wheel Shovel Mount, Lightforce Blitz 240's C/W Blue Filters, Outback Storage Draws, ARB Sand Dune Flag, Bushranger Max Air Compressor 40L Engel............
    Matt
    I put the Engel in the centre of the tie downs for the seats and run a ratchet tie down strap through the eyes and the Engel handles and ratchet it down tight. Doesn't move.
    DR
      As above said, Or:
      Mdf is a great idea, you can also bolt it to the centre seat holes for extra fixings.
      Make sure you use a suitable thickness to hold it if the thing ended up upside down! 16 mm or more. And through bolt your tie down points.
      I personally have just used tiedowns to the seat points and rear tie downs when in a hurry.
        EX-Prado Owner
          Thanks Guys,
          Looks like the MDF/Marine Ply is the Way to go! I'll take a trip down to Hardware Heaven....I mean Bunnings :lol: I can see this Temporary Fix being a Permanent one eventually.
          Matt (WA)
            Ahhhhh another white Prado in WA.
            If it weren't for the PINK plates on ours then I wouldn't know which was which at the shops when I came out!
            Welcome aboard.... :P
            Mitch
              MUMSRIG You're not wrong!
              I have The old Blue Private Plates too so that I can Pick it in a Crowd :lol:
              plus if you check out my old Pajero on my PBase Web site under 4x4 you'll see that was a one off too. It's amazing how many Prados you see When you've Got one! I hardly Noticed them 2 weeks ago before i got mine!! :lol: :lol:
              Thanks for the Welcome.
              Matt (WA)
