Running UHF antenna cabling
  • Running UHF antenna cabling
    Hey guys,
    I am currently having bit of trouble decicing where the best spot would be to run the cable for an antenna, ideally on your average car you would poke it through the firewall with the antenna for the stereo but as we all know thats not an option with a prado.
    steve
    Steve,
    2004 GXL 4L V6 4SP Auto, stock bullbar, GME TX3200... more to come.
    Through rubber grommet with other cables, left side of dash is easiest but
    you can also run through grommet on right of dash.
    There are little nipples you can cut off to run cable through, check out in
    engine bay.
    cheers
    leighw
      Cheers. Im now looking at cutting in to the flexihose with the main wirirng harness and feeding through there and trying to reseal it
      Steve,
        Just cut off one of the nipples next to the main loom on the grommet,
        push a length of wire through from the engine bay then use that to pull
        the coax through. Pull the coax tight then coat put some silicon around the coax
        for about 2cm and about 2cm from the grommet then pull the coax back a bit
        from inside the car, the silicon will form a doughnut and seal the coax.
Name:	2012-03-31 14.11.28.jpg
ID:	637549hey, cheers for the help guys. i fed it through that loom and now just have to get some silicone next time im out and it will be job done.
          i mounted it in the top of the glove box. looks a bit better than i thought and is tucked out of the way when not needed.
          Steve,
            Steve,
