amts - your inbox is full!
Rated recovery points
Originally posted by cfryback View PostHow did you go removing the bullbar chassis bolts?
I want to do the same thing, but haven't investigated on how to remove the bullbar captive nuts.2006 GXL 1KZ TD Manual
OK, I have bullbar already mounted....looks like I'm up for a challenge then!
Looking at getting the recovery points off of eBay - did they come with torque settings?[FONT=Century Gothic][B][SIZE=4][URL="http://www.pradopoint.com.au/showthread.php?36057-Ryback-s-Flinders-Red-120"][COLOR="#B22222"]'04 120 Petrol Flinders Red GXL[/URL][/COLOR][/B][/FONT][/SIZE]
Originally posted by cfryback View PostOK, I have bullbar already mounted....looks like I'm up for a challenge then!
I didn't get any torque settings with mine, just the recovery points and bolts.
Good luck, everything sounds easy when you say it fast.2006 GXL 1KZ TD Manual
Hey guys.
Looking to fit front recovery points to my 120 with an ARB steel bar on it. (non winch)
I see there is a few on the net and they quote that some peeps with arb bars have had trouble getting them to fit ?
I had a quick look under my rig and i can only see one bolt hole that it could go through ? was hoping i wouldn't have to drill the second hole ?
any help would be awesome . cheers.
ZuttaFollow The Zuttas OZ ADVENTURE on FB...[url]https://www.facebook.com/pages/The-Zuttas-OZ-Adventure/439583419452033?ref=hl[/url]
Hey Zutta I have a 120 with ARB bar and Amts recovery points. No new holes just reusing 2 that are holding the bar bracket on.
Cheers Matt
http://www.pradopoint.com/showpost.php?p=4890712008 120 GX D4D with a few extras
Rig build here
Originally posted by Mattfunk 120 View PostHey Zutta I have a 120 with ARB bar and Amts recovery points. No new holes just reusing 2 that are holding the bar bracket on.
Cheers Matt
http://www.pradopoint.com/showpost.php?p=489071Just what i was after m8.
Just on this I was in at ARB shop and they showed me a new ARB recovery point that basically you pull form a single point. Looked pretty good and they said they are very new from ARB so more models to come.
I called ARB and said so any chance of one for a 120 Prado and they said there is one in the system but no idea when it will be available.
Anyone heard about this?
