options available in 2005
  • options available in 2005
    hi,
    i'm looking at buying a prado and thought best to ask to people who know..
    I'm considering either the VX or GXL but was wondering what options or option packs were available in 2005 for the GXL.
    Any info would be great.
    cheers, Rod
    2005 VX V6 4.0L, Pearl White, Sovereign bar, nitestalker spotties, Tow Pack, Headlight & Bonnet Protectors, radiator bash plate, sandgrabba mats, cargo mat, DVD in headrest, radiator insect screen,
    G'day Rod,
    quick look or search in the general section should find a topic on the model history of what was released when and what it had.
      Echo....Echo......Echo....................
        that's what you get for being impatient i think... ooops..
        edit: mods can delete above if required, i don't have the delete button there..
          ok thanks will give it a go. I was actually after what genuine toyota options were available, ie was climate control dual zone a/c an option on the GXL, or did it only come with an options pack..
          thanks guys will try the search
          cheers, Rod
            from memory their was no option packs in 2005, only options were A/C bulbars etc in 2005. I could be wrong but am 95% sure.
            [b]Rob[/b]
              Ok, thanks so much. I kind of had that idea as i can't find any info on it.
              cheers, Rod
                Another site you can look at is ... REDBOOK .... call up the Prado model and Year that you are after and compare the specs.
                I've dumped the VX, GXL and Pilbara (a tarted up GX from the looks of it) models into a spreadsheet for an easy comparo ... Here.
                All of the spec lists on Redbook support Hutch's statement ... that there were no option packs in '05.
                Good luck
                Chippy
                  thanks an excellent site... found all info.
                  thanks to all.
                  regards, rod
                  Good luck
                  Chippy
                    Chippy to the rescue again!
