Reversing Cameras
  • Reversing Cameras
    Hi, just wondering if anyone has installed a reversing camera into thief 120. Any particular makes you would recommend or avoid? I know ARB do one, but are there any other makes worth a look at?
    some comments here
    http://www.pradopoint.com/showthread...Reverse-camera
      i fitted a $80 one from Repco last september. Doesnt have infrared leds but gives a great image and cant complain for its price. Its a wired one, previous camera was wireless and gave heaps of trouble.
      http://www.pradopoint.com/showthread...era-from-Repco
        Fitting a Chinese one tomorrow, got it off EBay for $20. Will let you know how it goes.
          Hard wired and works like a dream, 170 degree view.
            I installed a Navman MyEscape 11 when I first bout my 120. Obvious I needed a reversing camera to make back up to the camper easier. Noted that Navman make one to go with this GPS and RRP was $199. Found you could buy it from Officeworks online for $135. I paid to have it installed but if you wanted to do it yourself would have been relatively easy.
            It works a treat.
            Terry
            Canberra
              ASM, what was the sellers name for that camera ?? or was it a one off he had for sale ??......Cheers Steve
                i fitted a 20$ ebay one aswell... about 6 moths ago works awesome ! night time is brilliant aswell
                iv got the plastic wind deflector on the top of my back door and have double sided taped the camera to the window, wire just goes over the top of the door and into the trim
                  Has anyone fitted the type you see on ebay that replaces the rear licence plate lamp so it is a camera and light in one unit. Looks to be a very neat solution, but it looks like it is angled and that might be a bit weird using it when reversing into tight spots etc. Any feedback on this unit would be appreciated, as I am interested in getting one and this unit seems to be the neatest solution (looks more factory).
                  Blue 120 GXL Lots of ARB goodies and 1 mysterious switch fitted by previous owner - I still don't know what it does
                    Factory head unit upgrade and OE camera
                      Strike , parkmate , mongoose all make quality units but honestly on the size screen we view em on most cameras work fine. Got a jaycar 1 on the back and ebay one on the front of my rig ,work fine. So long as it's got a ccd sensor by sharp or sony, ip67 or higher and the viewing angle isn't to high (higher u go the more it distorts the image) you can't go wrong. Good ole safetydave does a good vid on camerashttp://http://youtu.be/qjw6km86S1Y
                      Here's my camera mounted above the towbar stealth style lol.
                      The road less travelled is definitely the best road to be on
                        Blue Box you can fit a 19mm bullet camera directly above your towbar , gives u a perfect rear view and looks factory. Sure I measured a 21mm gap between the towbar and rear bar when I drilled the hole for mine. Toyota towbar angles up and gives a bit of a void back there Wires go straight up into the car through the grommet for the trailer wire loom. Easy as.
                          did you get this done at a toyota dealer ? how much was the OEM head unit ?
                          thanks.
                            No I did it myself, $300 for the head unit from eBay or friendly dealer, $200 for the factory camera that plugs into the existing loom, job done. You can buy a cheaper camera but you then need to run your own cabling.
                              has anyone installed a system not in the head unit itself? Ive got a good single din head unit and dont want to replace with a touch screen style unit as the single din has everything I need. Wondering if anyone can recommend a good rear view mirror camera unit or something else? Was thinking of a small 3.5" screen but dont want to drill it into the dash via a mount so not sure. I could keep it in the centre console and pull it out when I want to use it but thats a pain.
                              I imagine that running the cabling all the way down from the rear view mirror camera kits would be a pain in the ass!
