Front recovery points - Alternative bolt method
  • Front recovery points - Alternative bolt method
    Hello All,
    This is my first post on a forum, ever, so be gentle!
    At AJ120's suggestion, I'm posting a method of bolting the front recovery points to the chassis in a way which distributes the load across the chassis cross section, which in turn allows more torque on the bolt.
    Method follows:
    1) Take a length of 6x50mm flat bar, and cut it long enough to straddle the chassis when fitted to longitudinally (front to back).
    2) Cut a hole for the mounting bolt, which is a Gr 12.9 countersunk/Allen key drive. I used Gr 12.9 because that's what the bolt supplier (Searle Fasteners here in Perth) had in the size I wanted, and high tensile.
    3) Countersink the hole so the bolt head is flush with the face of the flat bar when inserted. The countersink tool I used fits a normal drill chuck, and costs $100 or so - you could probably get a cheaper one on eBay, but regardless, its a handy thing to add to the tool collection.
    4) Fillet the edge of the flat bar with a grinder or bastard file (sod that I used a grinder) so when the bolt and flat bar are mounted to the chassis, the filleted edge will match the curve of the chassis.
    5) I think from memory I needed to enlarge the chassis hole by a bee's willy to get the bolt to fit.
    When fitted, there are two advantages to using this method:
    1) The 6mm flat bar spreads the compression load from the bolt to the chassis nicely, so you can really get some good torque on the bolt.
    2) There are no "sharp" edges (like the edge of a hex head bolt) to rub against the radiator plastic bit.
    I've attached some photos to show what I've done - hopefully they have actually attached (I'm a forum noob) but even more so, I hope they help someone. Any questions, or if this has been done before and I'm offending people, let me know.
    Tim
ID:	660216Click image for larger version
ID:	660217Click image for larger version
    Looks like a soverign bar you have on ??...Cheers Steve
      Yes it is a Sovereign bar. I needed to make a shim out of 5mm flat bar to go between the recovery point and chassis, next to the bull bar brace. Cheers, Tim
        Very reminiscent of my first post a very long time ago Which was about a different method of fitting that bolt as well!
        Looks good, looks neater than I thought it would just from the description and should be pretty easy for Joe average to do.
        I never liked the Idea of torqueing that bolt through the hollow chassis section; so good to see another option.
        You might want to trim that bolt as when you flex the body mount bolt might hit it a bit, otherwise looks like a top job.
          Hey Andrew, thanks for the kind words.
          I agree the bolt should be trimmed. Another grinder job...
          I might also mention the "greasy" appearance of recovery point is due to a healthy spray of Lanox. Smells horrible but is really good at inhibiting corrosion. I used to spray it on outboard motors to keep them schmick (job from a previous life) and the stuff is great for bright or painted steel, especially 4x4s.
            This is what I just did.....RoadSafe recovery points...Machined a sleeve 65mm in length, 60mm "under head", ID of 12mm and OD of 16mm. Left the head at 40mm OD and 5mm thick to match the lower bullbar mount (X-Rox bar). Drilled the top hole in chassis to 16mm (only outer) and pushed the sleeve in. Used 12.9 bolt @ 120 NM.
              That looks a good way to go for some vehicles and it looks quite nice too.
              Unfortunately this does not appear to solve the problem of Recovery points with ARB Deluxe bars fitted... I think this is a well known issue and very frustrating for a lot of Prado owners.
              Blue 120 GXL Lots of ARB goodies and 1 mysterious switch fitted by previous owner - I still don't know what it does
