Busy playing with all my new toys, it came time to give the air jack a test. Crikey, for just a moment, I felt I was about to tip the new Prado onto its side...
I found a few small challenges though eventually met with success.
Video of exhaust jack tipping my new Prado. This was about my 5th attempt.
Finally, some fun pics:
This is lifted much higher than is needed.
![](http://i274.photobucket.com/albums/jj241/LiveFreeAndRoam/4WD%20Accessories/AirJackLiftsthePrado120side-view.jpg)
There is still more lifting range in this air bag, which may be needed when bogged in deep soft sand.
![](http://i274.photobucket.com/albums/jj241/LiveFreeAndRoam/4WD%20Accessories/AirJackLiftsthePrado120.jpg)
The airbag is under considerable strain, but manages to hold the beast.
![](http://i274.photobucket.com/albums/jj241/LiveFreeAndRoam/4WD%20Accessories/AirBagtakestheweight.jpg)
There are many sharp edges and not too many safe lifting points.
![](http://i274.photobucket.com/albums/jj241/LiveFreeAndRoam/4WD%20Accessories/AirJackclearsthesharpedges.jpg)
LFaR.
- The first challenge was finding the best lifting point. With the side-steps, there are many sharp edges that needed to be avoided.[/*:m:2zmbu7bn]
- Adjusting the air bag so it did not deform too much during the lift required more fiddling than I expected.[/*:m:2zmbu7bn]
- Once the vehicle started lifting, the effort was too great for engine idle speed. At idle, the engined choked and stopped once the car started lifting. I needed my son to jump into the drivers seat (to his great delight) and increase the revs enough to inflate the bag.[/*:m:2zmbu7bn]
- The connector that fits over the exhaust is not an easy snug fit. Instead, it required a bit of fiddling to get it set at just the right angle. Also as the bag started lifting, it required considerable more effort to keep it in place.[/*:m:2zmbu7bn]
- I used some heavy cardboard to provide a little more protection against sharp edges under the car and pavement.[/*:m:2zmbu7bn]
LFaR.
