winch - bullbar or no bullbar
  • winch - bullbar or no bullbar
    Hi all
    I have a 120 v6, I really want a winch but I don't want a bull bar.
    Is it a requirement to have one in order to have a winch mounted or can I mount one without a bulbar?
    Thanks all
    My build thus far
    You could build a winch cradle to fit in behind the bumper. Not sure if ADR would approve.
      It's fairly common, particularly overseas to fit a winch but no bullbar. As rusty mentioned you would need a winch cradle and how that would go with airbag compliance would be questionable.
      I am not aware of anyone that makes one off the shelf, so you would likely be looking at a custom job.
        Wolf 4x4 have one listed on their website.
        http://www.wolf4x4.com.au/recovery-e...ser-prado-120/
        Bit expensive but I guess if that's what you want it is probably as cheap as a custom one.
        Edit- And apparently it isn't released yet, but worth a call to them I guess.
        [LEFT]Silver 150 Facelift
          Thanks guys
          wolf 4x4 make a couple I think. 1 for about $2k and one for $1k. quite a bit more than I was hoping to pay.
          Good point about the ADR, I didn't even consider this, maybe its best just to buy a bull bar. Anyone know of any going cheap around brissy? they seem to hold their value quite well.
            "Stealth" winch bar coming from Rhino4x4.
            News from this mob is that a Prado version is coming out soon. (but quite expensive)
            see link below.
            http://www.rhino4x4.com.au/news
            Steve
            2007 Prado 120 D4D 6 spd, 25/40cm lift ARB OME, snorkel, Brown Davis sump guard, Pirelli ATRs (Road), Cooper ST maxx (off Road), ARB lockers & compressor, Overkill rock sliders, dual D27F Optima Yelowtops, Ctek D250, 130A alternator, breathers, GME TX3440, Yaesu FT-857D, Buscomm Highlander 8 multitap or ATAS antenna, ARB Fridge. (VK2FSVN)
              I have a non winch arb bar & cant be arsed selling it & getting a new one - so im thinking of going for something like this: http://www.ebay.com.au/itm/TREX-4WD-...item1e78235d9c
              Can be used on the rear tow hitch & I personally cant see any reason why you couldn't connect it to front recovery points via an equaliser strap & use it that way.
              Best of all, you can take it out and put it in the shed for the daily commute!
              Thats my idea anyway...
