What's the height of the top bar? Easiest way to measure is to clamp something across the top of the rack then measure from that to the ground.
ARB roof rack
Originally posted by blkmav90What's the height of the top bar? Easiest way to measure is to clamp something across the top of the rack then measure from that to the ground.My Rig Buildup [url]http://www.pradopoint.com/viewtopic.php?f=38&t=4918[/url]
Re:
Originally posted by KevinOriginally posted by blkmav90What's the height of the top bar? Easiest way to measure is to clamp something across the top of the rack then measure from that to the ground.
EDIT: Okay, with the spare D694 up top, the overall height rises to just under 2.20m. I reckon you'd need a clearance height of 2.25m to be sure. 8)[B][SIZE=4]ntp
Re: ARB roof rack
I am just wondering if anyone can comment on the effectiveness or not of the ARB roof rack wind deflectors? Do they really make any substantial difference to the noise levels caused by the roof rack? Anyone able to provide comments from direct experience?[B][SIZE=4]ntp
Re: ARB roof rack
ntpryce,
When I got my rack my local ARB reseller, told me not to bother wasting my money on the deflector. If you want to reduce the noise you could always put some ply up top to reduce the airflow through the bars.
I just turn the radio up.
Adrian2004 GXL TD 3.0 ARB deluxe bar, Warn winch, IPF Driving lights, Pirhana Dual Battery, Pirhana Dual Battery Monitor, GME UHF, ARB air compressor, Custom storage/ fridge slide, ARB roof rack, Safari snorkel, 2" OME suspension lift, Mickey Thompson MTZ
Re: ARB roof rack
Adrian[B][SIZE=4]ntp
Re: ARB roof rack
Pryce,
The ARB wind deflectors do decrease wind noise a little bit compared to the empty rack, but I also found that it also increased fuel consumption slightly. The effectiveness of these wind deflectors depends a lot on what you are carrying on the rack. If you have some odd shaped bits a pieces on the rack then it might make more of a difference. For me the rack is either completely empty or completely full with a Michelles Sac Roof Sac,
so I haven't seen any real benefit of having the wind deflector attached.
Hope that helps.My Rig Buildup [url]http://www.pradopoint.com/viewtopic.php?f=38&t=4918[/url]
Re: ARB roof rack
Originally posted by KevinFor me the rack is either completely empty or completely full with a Michelles Sac Roof Sac
Originally posted by KevinHope that helps.[B][SIZE=4]ntp
Re: ARB roof rack
nice setup there with the rack mate[B]My 2007 D4D [COLOR=darkred]Flinders Red[/COLOR] Buildup[/B] - [URL="http://www.pradopoint.com/showthread.php?13590-Golly-s-Flinders-Red-D4D-GXL"] HERE[/URL] :cool:
Re: ARB roof rack
Postby Kevin on Sat Oct 04, 2008 5:48 pm
ntpryce wrote:
photoprado wrote:ntprice, what does the whole shebang weigh?
Sorry ~ I don't know. An email to ARB would give you the answer, if no-one else can help here.
Around 50kg...Hence the pulley blocks to get it off the roof.
My Rig Buildup http://www.pradopoint.com/viewtopic.php?f=38&t=4918
Can anyone confirm that? Very interested in getting one myself, just waiting for the green light from the financial controller :PLG - Life is Good!!!!
Re: ARB roof rack
I haven't seen or heard of an ARB aluminium roof rack :?:
I still prefer the strength and durability of the steel deluxe racks; they've never let me down in the past. 8)[B][SIZE=4]ntp
Re: ARB roof rack
Originally posted by ntpryceI haven't seen or heard of an ARB aluminium roof rack :?:
the link above will take you to the arb site about the rack.
I only come across the site since I was curious when I was told that the rack is only less than 30kg, where as lots of people here said it weighs no less than 50kg.
Why do you think the aluminium rack would not be stronger or at least equal in strengh to the steel ones? I thought ARB would make it at least the same sort of quality of the product they are replacing? Just curious :?LG - Life is Good!!!!
Re: ARB roof rack
i also heard when buying my steel rack the aluminium one would be out soon ... the day my gear was fitted a few weeks ago my cairns dealer had just came back from a week of ARB australian conferences...
alloy is coming. powder coated an\d as strong..
joeyFeatured - issue 140 Australian 4wd Action.
-issue 52 Modified 4wds .
Re: ARB roof rack
Looks good... a bit like having a security screen door on your roof. :wink: :lol: :lol:
Wonder what the price difference might be?[B][SIZE=4]ntp
Re: ARB roof rack
Hi, i just had the alloy rack fitted on friday, looks good, while i cant comment on the weight side of things, it was either $964 for the steel or $1264 for the alloy fitted, at arb nundah. The mesh floor is standard thats all they come out in i was told. cheers08 GXL Diesel Auto,ARB bar/roofrack, ATS liftkit
