Warn 9.5XP in Soverign Bar
  • Warn 9.5XP in Soverign Bar
    Does anyone know if the Warn 9.5XP or XDC will fit in the Sovereign Bar?
    Nathan
    2012 GXL Prado D4D
    Re: Warn 9.5XP in Soverign Bar
    yep they will fit, the bolt pattern is std thing all ya need to do is go and get a winch cradle, they r about $220 from toyota :wink:
      Are you absolutely sure the 9.5XP will fit? The sales manager at ARB Hoppers Crossing told me that i will not fit the Soverign Bar.
      2012 GXL Prado D4D
        Perhaps he wants you to buy an ARB bar as well! :lol:
        Black 2008 D4D GX, Bolle tint, Airtec snorkel, Hayman Reese tow bar, Staun deflators, ARB Air, front & rear extended diff breathers, Milford cargo barrier, Poly Air, 2" lift, XGS suspension, road tyres - 265/65x17 Grandtreks, play tyres - 265/70x17 Wrangler MTR's, ARB Sahara Bar, TMax 9000 winch, custom winch panel, Uniden UHF, Garmin 76csx with RAM mount, Eee PC with OZI, triple IPF 900XS spotties, rear ARB diff locker, Brown Davis underbody protection, Darren McRAE Auto Craft Rock Sliders
          Pretty sure Chippy has one in his toyota bar...
          -issue 52 Modified 4wds .
            Chippy and I both have Warn XD9000 in Soveriegn bars and it is a tight fit.
            As far as I know the 9.5XP has a larger motor than the XD9000 which may pose an issue in fitting it between the bracing.
            Note the Soveriegn is designed to have the cable wind on to the winch over the top of the spool, whereas Warn winches are designed to have the cable wind on to the spool from the bottom. That means to fit a Warn winch to a soveriegn bar it needs to installed backwards (with the motor on the opposite side).
            Leachy
            EX-Prado Owner
              Here's the XD9000 tucked up under the bar .....
              Chippy
                The ARB sales guy was definately trying to upsell....
                It sounds like a safe option considering the no one can confidentky tell me that the 9,5xp will fit, that I should just buy the xd9000.
                Has everyone mounted the solanoid in the engine bay?
                2012 GXL Prado D4D
                  Here is a couple of pics of my solenoid box mounted in the engne bay.
                  As soon asI get around it, I will be replacing the Warn soleninds with this Albright unit (the one Albright unit replaces all four Warn Solenoids).
                  Leachy
                  EX-Prado Owner
                    The 9.5XD is 2cm longer on the motor side and same diameter plus cooling fins.
                    Chippy, can you please have a look at yours and see if there is 2.1cm clearance at the motor end of your xd9000? Is there 0.5cm clearance around ther perimeter of the motor end for the cooling fins?
                    Thanks very much.
                    2012 GXL Prado D4D
                      Nath, you might want to check out this months 4WD action, big test on winchs, the 9.5XD come up second to the Premier and it was $500 cheaper, worth a look before you fork out your hard earned cash. I have no idea of the dimensions and suitability of the later, just thought i would flag it.
                      [b]Rob[/b]
