Power windows - problem
This topic is closed.
  • Power windows - problem
    Recently had my snorkel fitted and just noticed my rear windows dont work from the drivers control panel. I believe this is connected because I think they disconnected the battery as my clock reset and my SatNav system also was reset to default.
    Is there anything else I should check after the battery is disconnected?
    2008 Charcoal GXL V6
    [b]Suspension[/b] >< OME springs and shockers
    [b]Tyres[/b] >< Pirelli Scorpian ATR
    [b]Chassis[/b] >< ARB Deluxe Bullbar><Tow bar
    [b]GPS[/b] >< AVIC HD3>< Ncom G351 running ozi
    [b]UHF[/b] >< GME3440
    [b]Accessories[/b] ARB Dual battery system><Rear Camera><Safari Snorkel>
    [b]Brake Controller[/b] Hayman Reece
    Re: Snorkel problems
    if the windows dont work from the drivers control panel, just turn the ignition to on and cycle each window form its door control, then it should work from the drivers door. cheers samo
      try this one http://www.pradopoint.com/viewtopic....=window#p45784 for the windows thingy
      07 Prado GXL, D4D manual, silver and a fridge with constantly changing beer levels.
        Cheers guys, I should re name the thread as its nowt to do with the snorkel.
          Re: Power windows - problem
          Actually as it is a triple up post on the power window issue it shall be locked away.
