Install of ARB Air Compressor - CKMA12 in a V6 Petrol 120
  • Install of ARB Air Compressor - CKMA12 in a V6 Petrol 120
    nice work there matt, seems like you have been a busy lad, see even diesel fitters can do 12v
    Re: Install of ARB Air Compressor - CKMA12 in a V6 Petrol 120
    top job Matt..
    looked like a busy little session there.. 8)
    joey
    -issue 52 Modified 4wds .
      She's a bewdy Matt.
      Originally posted by pradogxlv6
      I had to make a spanner to securely mount the compressor, as it is tight. Also when I wIred it up, I was going to wire it to the aux battery, but ARB told me to go for the start battery.
      Sheesh, there's no room left under there now.
      And that spanner... what a classic!
      I couldn't wait to test mine out after I finished my install. Have you given it a go?
      LFaR.
        How much did you pay for your Yuasa battery?
          About bloody time!!
          2000 Toyota Prado GXL- Gone, but not forgotten...
          '92 Landcruiser HDJ80 4"lift 33's
          '91 Surf LN130 coil sas, 4.8s, 35s
          '12 Jayco Eagle Outback
            HI
            thanks for a good write up
            Trev L
            Prado 2003 with a OME 2 inch lift, ARB Delux Bullbar, Warn magnum winch, IPF 9000 spots, Safari snorkel, Daul Batterys, UHF Radio with remote head unit, extra Power outlet, 265 70 17 MTZ's, ARB CKMA12 Compressor, TrackLander Roof rack with two Rear Work lights, rear anderson socket, twin DVD Players, Indash DVD,GPS, running IGO 8 and OziplorerCE, Custom Drawer System
              Good one Matt.
              I've also had discussions of having the filter extended through the firewall into the cabin. I guess this could make sense in very dusty environments where the air-lockers would need to be operating. Stretching it all the way back into the cabin makes for a long straw and one that I think would impede tyre-inflation speed. Still, probably not a bad trade-off if it's really needed in those environments.
              Your hose looks nice and short, so I wouldn't expect much/any change in performance.
              LFaR.
                Hi Matt
                I just purchased the ARB air compressor switch but they could not tell me what wire goes to the 5 pins on the rear of the switch....
                Can you remember what goes to each pin.
                There is three on one side and two on the other.
                Jack
                  Originally posted by jack76
                  Hi Matt
                  Jack
                  The side with two is the power from dash lights and negative for helping to find the switch at night. The side with three is accessories in, accessories out (to relay) and negative to show light in the on position (altough you will hear the bloody thing). Should be in the install documentation supplied with the unit but here is a diagram I put together to help me with setting up an ARB switch base for driving lights. Same pin configuration:
                  The the pin marked "Ground (Lights)" can be joined to the other ground as there is no floating nagative (I think it's called). The pin marked "+12V(Highbeam)" can be linked into your accessories ciruit so that the compressor can only be controlled when accessories are on unless you wish to run off of your Aux battery
                  [COLOR=#000080]Nick[/COLOR]
                    Thanks Nick
                    That is great. I just purchased the switch by itself and they couldn't tell me how to wire it up. I will get on to it soon.
                    I am just going to replace the current switch i used but i like the idea of having the switch labeled.
                    Jack
