Replacing Horn
  • Replacing Horn
    Does any one have the instructions on how to replace the OEM horn with the dual Bosch horn units? Do I need the relay? I will probably have to cut into the OEM wires.
    In the current set up, two wires go into one horn and only one into the second. Any assistance would be highly appreciated.
    Cheers.
    Re: Replacing Horn
    I did the following recently, and it works wonderfully:
    Identify the +ve horn wire using a multimeter.
    Piggyback off that wire, and take a wire to term 86 on a 30A automotive relay.
    Run a fused wire from battery to term 30 of relay.
    Earth term 85 of relay.
    Run a wire from term 87 of relay to +ve terminal on your new horn/horns.
    I fitted a Stebel Nautilus to my Prado using this method - a short tap on the horn button produces a factory 'beep' while a pissed off push of the button unleashes a great racket. I also used the same method to fit a Nautilus Compact to my R1200GS, with good effect.
    P
    2008 Prado 4.0 VX
    ARB bullbar with Warn winch
    Ironman Suspension
    Safari snorkel
    Windscreen washer upgrade!
      Re: Replacing Horn
      Will this same method work for a twin horn setup? Do I have to use a relay when replacing the horns? I thought that was for older cars. Cheers.
        Re: Replacing Horn
        Hi all,
        Just a word of caution, not sure about the other states but in VIC the vehicle design rules state
        that you can only have a one tone horn, ie non musical. It seems air horns with two trumpets that
        operate together are considered as two octaves but one tone, ie the same as the OEM, one
        high and one low horn and not musical.
        Having both the original horns and and air horns operate together would be classed as two tones or
        musical even though they don't play a tune, and therefore still illegal.
        In my case I did basically they same except removed the OEM horns and used the mounting points
        to mount the trumpets.
        Also, be wary of the wiring and don't run the cabling of the air horn compressor across the face or to close
        to the front impact sensors or you might have more than just the horn go off when you press the horn buttom :cry:
        LeighW
        front imp
          Re: Replacing Horn
          Hum, so many comments to make.....................
            Re: Replacing Horn
            I would not have a problem with such a rule because it makes sense. Maybe they should make it a rule to have manufacturers install loud horns as OEM equipment so we do not have to change them. . . .Any install instructions with photos would be appreciated.
              Re: Replacing Horn
              Hi BAZPRADO,
              Do a search for "Nautilus" under the electrical heading and you'll find a lot of info
              there.
              If you still need help after that I'll post some pictures of my setup for you.
              LeighW
                Re: Replacing Horn
                I will try the search function.
                Cheers.
                  Re: Replacing Horn
                  Where do you get the Stebel horns from? (Sydney)
                    Re: Replacing Horn
                    eBay looks like the go if your game!
                    http://shop.ebay.com.au/?_from=R40&_...All-Categories
                    [size=2][b]2009 GXL D4D Auto[/b]
                    - A white one - Cooper STs all round - Sandgrabba floor mats - ARB Sahara Bar - Rola roof bars - Stebel compact truck horn - Tekonsha P3 brake controller - Couplertec electronic rustproofing - ARB Recovery bag and gear[/size]
                    [url=http://www.fuelly.com/driver/GDSPrado/prado][img]http://www.fuelly.com/smallsig-metric/48415.png[/img][/url]
                      Re: Replacing Horn
                      trialled the factory crewman horns a few months ago...found the same items from a wreck ie brothers commodore..just traced out the wires and ran new earths..everyone now looks for commodore/astra whenever i get horn happy...
                        Re: Replacing Horn
                        Originally posted by LeighW
                        Hi BAZPRADO,
                        there.
                        LeighW
                        Hi Leight,
                        I would definitely appreciate your pics to help me find the right wires to tap into, especially given that only clips are going into the OEM horns.
                        Cheers mate.
                          Re: Replacing Horn
                          My 120 had two factory weakling horns. My guess is that this is a stopgap solution because Toyota has also realized that the horns they fit to the Prado's aren't loud enough. So yeah, you can pull one horn out and use the wiring leads to activate something like a Stebel air horn which many of us have done. Check the electrical forum for details, but what it boils down to is using the existing horn power lead to activate a relay. That then pulls juice straight from the battery or another more meaty power supply when you mash the horn button on the steering wheel. With this setup I also get a second or so of the standard horn before the Stebel kicks in.
                          the thread you want is this one http://www.pradopoint.com/viewtopic.php?f=16&t=618
                          I notice it's near the top in the electrical forum anyway so you can't miss it.
                          Definitely a worthwhile mod. No regrets on my end.
                            Re: Replacing Horn
                            Thanks. I will give it a shot this weekend, I might be able to do it without using the relay, I am using two horns in a manner similar to the OEM installation. Cheers.
                              Re: Replacing Horn
                              Baz,
                              You will need the relay and run another wire from the battery. If you do not the cable is not big enought to hand the current draw on both horns and most important the NEW HORN~!!! :lol:
                              Manata 3" Exhaust, Blisten shocks, King Springs 50 mm lift, Poly Air Bags, Roof Rack, Iron Man Bull Bar, HID 50W LightForce XGT spotties, Daul Batteries, GME TX3440 & AE4705 ant, Upgraded window washer, Bonnet Scoop, Tunit chip, bonnet protector, headlight protector, Cooper STT's, ScangaugeII, Dash Mat, Endless Air, Stebel Nautilus, Diff Breathers, Water Sedimentor. ([b]Camprite TL8s [/b] Arrived ALIVE~!)
