SAFARI SNORKEL TEMPLATE LOST
just had thought in regards to scanning the template, instead of tracing around the outlines of the template and holes, a dark piece of paper could be placed behind the template when scanning and that should produce a clear image.2007 VX 1GR-FE, Dune, ARB Sahara Bar, Waeco CF-50, Dual Battery, Alinco UHF CB, DIY Drawer and DS40 drop slide, Tinted Windows, HR towbar, Dash mat, IPF900 HID converted, Warn M10000/ synthetic rope, extended Diff and Gearbox Breathers, Tough Dog Suspension lift Kit
Originally posted by Steve M View PostLooks good sjc. Can you post some further pics of engine bay as well as you go ??.....Cheers Steve
My snorkel has been on few a while now but i took a few photos for a mate who was also fitting a snorkel on a 120
Here are a few tips.
*Go to Toyota and get some new inner guard clips as they are hard to remove and will more than likely break when being removed.
*Use a good quality 95mm hole saw and a step drill for the smaller holes.
*Make sure you treat/paint any bare metal around your new holes.
*I put tape on the pillar so i could mark right position for the bracket before drilling and also protects paint from scratches. I also put tape over the flare to stop any metal filings getting in between the guard and flare.
*I used a tiny bit of silicone around the plastic A pillar plugs before inserting into hole to stop moisture getting in.
Cheers sjc, I did buy some new clips but will have to search for them. I did buy them over two years ago when I bought the snorkel lol if not they were only a couple of $$ for them anyway.... Thanks for the tips on the tape as well, appreciated.... Cheers SteveFace lift 150 Prado V6 auto. No mods yet
Thanks for going to the effort to trace the template for me Steve, unfortunately I need to work this Sunday, I can pick it up from you another day if that works.2007 VX 1GR-FE, Dune, ARB Sahara Bar, Waeco CF-50, Dual Battery, Alinco UHF CB, DIY Drawer and DS40 drop slide, Tinted Windows, HR towbar, Dash mat, IPF900 HID converted, Warn M10000/ synthetic rope, extended Diff and Gearbox Breathers, Tough Dog Suspension lift Kit
Yeah mate no probs.....Sent ya a pm...Cheers SteveLast edited by Steve M; 10-04-2014, 08:50 PM.Face lift 150 Prado V6 auto. No mods yet
Thanks Amts appreciated, Will make sure of that. Anyway I have to may be offer Rob a slab or some thing yet and see if he will let me borrow his hole saw and step drill so I can do it or as he said make a work day of it doing his and mine together......All tips help do a good job.......Cheers SteveFace lift 150 Prado V6 auto. No mods yet
no slab needed, Steve..hole saw and stepped drill are yours to borrow....you scatch my back I scratch yours
or tech day if you prefer.2007 VX 1GR-FE, Dune, ARB Sahara Bar, Waeco CF-50, Dual Battery, Alinco UHF CB, DIY Drawer and DS40 drop slide, Tinted Windows, HR towbar, Dash mat, IPF900 HID converted, Warn M10000/ synthetic rope, extended Diff and Gearbox Breathers, Tough Dog Suspension lift Kit
[IMG][/IMG] [IMG]
[/IMG] [IMG]
[/IMG] [IMG]
[/IMG] Rob Not sure if you needed these or not but Im going to Tassie and forgot to get your email. Was going to post but presume you can print from these pics. If not send me a PM and I will check for messages while away. I do have downloaded to photo bucket so I may be able to get on line some where with a printer while away and post to you if you need them before I get back.....Cheers Steve Obviously they are here for any body else that may buy a second hand snorkel and need the instructions....Cheers Steve
