Sliders from WASP 4x4 and other manufacturers
    Re: Sliders from WASP 4x4 and other manufacturers
    Originally posted by Muddles
    3. Now they are on the vehicle feels different to drive. I assume at this stage it is to do with the fact that the original steps are attached to the body rater than the chassis rails. There is a bit of a vibration that wasn't present before the change and i think this is to do with the fact that i have just added 15kgs to each chassis rail directly with no padding between the rails and the steps to stop the vibrations passing back up through the body.
    A couple of things: check for mounts rubbing against cabin and I also noticed the vibration when I installed my slides from Autocraft, very minor but still noticeable.
    2014 Toyota Prado 150 D4D Auto (facelift); ARB Deluxe Bullbar; OME 2" Lift; Rhino Pioneer Platform Rack; Redarc BCDC 1225 with Optima Yellow Top; BF Goodrich Mud Terrain KM2; Lightforce Genuine Custom 70w HID; GME UHF; Safari Snorkel; Rigid Industry SR-Q2 side lights (yet to be installed); Domin8or winch (yet to be installed)
      They look the good muddles.
      1. When fitting them i had to release the brake lines that were attached to the chassis rail. they then had to go on back under the rear arm which may leave them a little exposed although when reattached to the chassis rail they are still above the bottom of the rails
      Is that because of the welded gusset on the mounting frame of the slider?
      Interesting observation. Have you noticed any rubbing between the sliders and the body when the body flexes away from the chassis? It's not the aluminum checkerplate vibrating is it?
        So far i haven't seen any rubbing on the body but it has only been a few days. i will have a look at the weekend to see if there is any point where this is occurring.
        Yes the gusset that gives the extra support from the mounting bracket to the arm is what gets in the road but i think it is better that they are there for the extra strength.
        2006 GXL D4D, Gun Metal Grey, Soverign Bull Bar, Uniden UH400SX-RM CB. Rock slider steps from WASP, 2" Lift Bilsteins with King Springs, Cooper ST Maxx 265/70/17's and a Safari Snorkel. My Wife's future shopping list includes in order a Winch (Most likely a Tigerz), Bash Plates, Rear Bar, Dual Battery setup and a 60l Fridge. And the list gets longer each time we talk about the car.
          Is that vibration still noticeable? Do you think there's a way of 'fixing' it?
          I am about to buy a set from Auto-Craft too...
            I can't say that it is gone but it is only minnor. The only way i can think that you may lessen the vibration is by using some sort of rubber bushes to absorb the movement and with the space available on the fule tank side you may not be even able to get them on there.
            As pointed out by Fungi this is something that seems to occur wether they are from autocraft or wasp.
              I've got ATS sliders (I assume the Autocracft ones are exatly the same as Darran was formerly at ATS before starting Autocraft), and I have no vibration / noise issues at all. Though I did modify the driver's side rear mount to provide more clearance from the body gusset.
              Leachy
              EX-Prado Owner
                I rounded off the corners of the mounting plates, which reduced the chances of contact with the body.
                I also had to move the rear mount top holes back an inch to avoid a body pressing.
                Nothing a 10 mm body lift wouldn't fix :lol: :lol:
                Also have a look at the tabs that hold the checker plate on the inner edge of the steps.
                There's a chance they are touching the body.
                Any contact between step and body will give a resonant drumming sound.
                Chippy
                  Slider Update.... New style available soon... Check my thread!!
                  http://www.pradopoint.com/viewtopic....=7394&start=80
                  Mitch
