hi all
I thought it is good to share this with you may be someone find it useful
Photo 01
Is showing the guard that I want to remove
Photo 02
Then we have to remove the 4 Screws that locate under the plastic guard as shown in the photos below
photo 03
Then you have to remove the 2 screws that hold and carrying the guard from behaind the plate numbers
as shown in red circles
photo 04
When you de attach the guard you have to move slowly and direct to up here you see the front plastic guard after de attach it
And to move the black metal part first you have to remove the 3 plastic nails as shown in photos 05 and 06 below and then you have to remove the plastic part that located behind the bumper as shown later
photo 05
photo 06
photo 07
showing the plastic part that we have to remove
photo 08
first you have to de attch it from the top as in photo below
photo 09
and then from the bottom
then you have to go under the car to remov it see photo 10
photo 10
once you remove the plastic part you will see 4 screws and Nuts all what you have to do is to remove these 4 Nuts and then press on the small plastci nail in the middle and Black metal will fail dwon automatically
photo 11
then it will look like this
photo 12
photo 13
use a White tape to cover the holes temporary
thanks
Photo 01
Photo 02
photo 03
photo 04
photo 05
photo 06
photo 07
photo 08
photo 09
photo 10
photo 11
photo 12
photo 13
thanks
