Hi all.
Recently my scanguage2 started having issues with the LED readout.
The left side of the scanguage2 started with some missing LED parts on the readout. It seems it extended to both rows but only 1/2 way across. Other symptoms were on occassions, the right guages would fluctuate, or rotate through as if you kept pressing the buttons. I confirmed the buttons were not depressed. 2 weeks on from the initial faults showing, the scanguage is missing most LED parts on the left side of the screen so now it is impossible to r theead.
I removed the scanguage completely and reinsterted in - same faults
Changed the connection from the rear socket to the right side socket - same faults
I removed it and left it out for 24 hours - same fault
I opened it up and removed the ribbon cable and reinserted it - same fault
Any suggestions as to the cause. I think its about to go in the bin as I dont believe that it is repairable because when LEDs normally do this, they are stuffed. I am hopeful it may be an easy fix, but I dont think it will be.
What are the alternatives to the Scanguage2. I really like the concept of the trip computer showing fuel usage etc.
Thanks in advance
Thanks in advance
