I've seen a few 120s with a small flat disc-like spare wheel cover, that covers only the wheel rim, not the tyre. They appear to be fixed by a nut or something in the dead centre. Anyone know if this is a Toyota thing, or after-market? And do they require anything special on the spare wheel bracket, or do they fit all? I quite like the look of them, and might like to try one.
Spare Wheel Covers
Spare Wheel Covers
White 08 Standard with ABS/cruise option pack, D4D/6-man, std 6" steel rims with Cooper AT3 235/70R17s, added roof rails, bullbar, towbar, ScanGauge II, custom-built aux power pack, Bushman multi-capacity fridge on slide, on DIY removable false floor. Often towing an Ultimate camper-trailer.Tags: None
Yes,that's the one, thanks guys. Obviously mine is not a Grande, so might have to go and talk to Mr Toyota about this. If it's a Toyota part, might be a bit too spendy!
Cheers, Steve.White 08 Standard with ABS/cruise option pack, D4D/6-man, std 6" steel rims with Cooper AT3 235/70R17s, added roof rails, bullbar, towbar, ScanGauge II, custom-built aux power pack, Bushman multi-capacity fridge on slide, on DIY removable false floor. Often towing an Ultimate camper-trailer.
Good thinking...done.White 08 Standard with ABS/cruise option pack, D4D/6-man, std 6" steel rims with Cooper AT3 235/70R17s, added roof rails, bullbar, towbar, ScanGauge II, custom-built aux power pack, Bushman multi-capacity fridge on slide, on DIY removable false floor. Often towing an Ultimate camper-trailer.
If you want a full wheel cover I have mine going cheap, I'm just using the one that's pictures above nowMy Grande Build Up
[url]http://www.pradopoint.com/showthread.php?25867-My-04-Grande-Build-up[/url]!
My Hilux Build Up - R.I.P
[url]http://www.4wdaction.com.au/forum/viewtopic.php?f=22&t=121302[/url]
The scratched one on the right. And I must correct you. The better question is: "Which one WAS mine".
The one design fault in the MCC rear bar is the license plate fixing system. It makes getting it off very diificult. I simply fixed the light and plate direct to one of the covers and can now remove either wheel and put the cover on the remaining one. (Well almost, I need to extend the wire)
