Rear bumper removal
  • Rear bumper removal
    Hello all,
    Sorry if this is a daft question, but I looked in the search but didn't find.
    I want to replace my rear bumper,
    A 'how to' would be nice.
    'vette
    Highest bungee jump in the world.
    [url="http://www.youtube.com/watch?v=OxxTDQzRrkU"]http://www.youtube.com/watch?v=OxxTDQzRrkU[/url]
    Re: Rear bumper removal
    deleted my post because I realised I don't understand what exactly you mean... :?
    [size=2][color=#00BF40][b]2003 120 GXL V6 auto[/b]. GME TX3440 and AE4703, Mickey Thompson ATZ 4 rib LT265/70R17 plus roadies, Ausguard cargo barrier, BD bash plate, OME lift with Sport shocks. And hopefully more to come, slowly slowly...[/color][/size]
      I managed to do it quite easily and far quicker by slamming it against a big rock as I was coming out of a creek :roll:
      Just knocked it back in and put zip ties on it...and I still haven't got new bolts on.
      Haven't considered a steel rear bar? That's what I plan on once mine eventually gets knocked around too much.
      Cheers - Phil Taylor
      Prado KZJ120 2006 GX 3.0ltr Manual TJM T13 Bar, Airtec Snorkel, Sand/snow mats, cargo barrier, Cruise, Budget Campertrailer, 8x17" steelies w/ 265/70/R17 Mickey Thompson ATZ 4 ribs, Binatone GPS, Other Stuff...
        Whats there to understand.
        1. Take bumper off.
        2. Put bumper on,
        I will try to make it more simple. :mrgreen:
          It's been quite a while since I've done it however from memory it's quite easy... there a number of screws under the bar around the edge and a couple on each inner side attaching the bar to the flares (these could be clips, can't remember) - you should find these easily. Undo the trims above the bar - everything is reasonably obvious and there are two fasteners on each side of the bar at the top (where the inner rolls up verticle, near the rear reflectors). You may need to undo the rear door retainer thingy - the bit that holds the door open. Then simply pull back and she unclips at the sides. There are little clips/lips on each side which push into the flares - these will pop out and push in etc. Be carefull to ensure you unplug anything electrical before you pull the bar cover off such as reversing sensors.
            Originally posted by uk_vette
            Hello all,
            'vette
            [quote=uk_vette]
            1. Take bumper off.
            2. Put bumper on,
            I will try to make it more simple. :mrgreen:[/quote:3gbp8x5h]
            So your 'question' is that you are after specific instructions on how to take off your exisiting bumper bar. Not how to replace your exisiting bumper bar, or advice on aftermarket alternatives. if you're vague your posts than people can interpret your 'question' in different ways. :roll: :roll:
              [quote=WBY 1]
              Originally posted by "uk_vette":1rkfqfsr
              Hello all,
              'vette
              [quote=uk_vette]
              1. Take bumper off.
              2. Put bumper on,
              I will try to make it more simple. :mrgreen:[/quote:1rkfqfsr]
              So your 'question' is that you are after specific instructions on how to take off your exisiting bumper bar. Not how to replace your exisiting bumper bar, or advice on aftermarket alternatives. if you're vague your posts than people can interpret your 'question' in different ways. :roll: :roll:[/quote:1rkfqfsr]
              I just want to take off my existing rear bumper, European LC4, with turn and tail in the bumper,
              then fit a LC5 bumper which does not have the turn and tail in the rear bumper.
              I have now got the turn and tail working in the main rear light clusters.
              I am swapping the bumper because I am putting this on.
              but as you see, it would obstruct the lights in the current bumper, hence the swap out.
              Thanks for the help
              'vette
                UK_Vette
                PM me with your email details and I will send you detailed instructions (which were sent to me by Quicky) on how to remove a 120 rear bumper
                Snappa :twisted:
                '06 RV 1KZ-TE, BFG AT's LT 265/70/17 (2nd set), Hilux washer jets, Bosch Aero Wipers, Nokia Bluetooth car kit, Safari Snorkel, 12v ARB Portable Compressor, Hi-lift jack & winch kit, Unifilter Reusable Airfilter, DP Chip, ProVent 200
                  Grave dig.
                  My Prado is finally getting the rear bumper replaced and HR towbar fitted next week. Do I need to remove my drawers to enable the panel beater to remove the bumper?
                    From this pic looks like I do, has anybody removed their rear bumper?
                      Hi Snappa, I am new to prado point, what a site. Is it possible to send me instructions on removing the rear bar. I have purchased a genuine towbar kit for the 2006 prado and want to fut myself to save $$$ i have the harness as well.
                      Do you know if there are any instructions for the complete job including where to feed the wiring harness through. Cheers
