I have done quite a few trips to Fraser Island, some of a few days and others of up to 8 weeks. When I return home I give my vehicle a good cleanout underneath. However to do this properly you must remove the bash plates as sand becomes packed in the cross member above the bash plate and can't be seen. This has also happened to two other Prado owners I know. Definitely a potential rust spot if ever I've seen one.
Sand trapped in cross member above bash plate.
Re: Sand trapped in cross member above bash plate.
On my very first venture to Stockton beach, (my Prado had just 300km;s on the clock, so proud) I was advised to get a soaker hose, lay it down drive the car over it and gently loosen the sand with the hose. If you get under there with a jet blast of water, you will compact the sand and make it harder to get it out..
To my surprise, it worked an absolute treat..D4D Prado GXL - 2014. 2" OME lift, ARB Deluxe Winch bar, ARB under body protection plates, ARB EZ Deflator, Weaco fridge, Matsen fridge on slide, BFG A/T's, ARB CKMA12 compressor, Oztrail side awning with LED lights PLUS canvas extension, Lightforce XGT's.. Oricom UHF380, GME AE4017
Took the bashplate off to get access to the front diff and found all the mud there even though the car had been detailed previously with instructions to thoroughly clean the underside. Now that I know how easy it is to take the bashplates off, I will be doing it everytime the underside of the Prado needs a clean. You'll save a lot of time and water, especially when using a high pressure cleaner.
Hi Guys
On our return leg of our Trip To The Tip 2010, We encountered the automatic under body wash at Lakeland. This is run by the Qld. Government to remove any weed seeds and plant material and therefore prevent transfer to other Agricultural or Horticultural regions. This thing was amazing, simply drive on and slowly move forward. We did about three passes and it sure cleaned the vehicle and camper of all the accumulated crud from underneath.
Back in S.A., There is a car wash in Pt Lincoln that has an under vehicle jet system. We used this a couple of years back after two weeks of beach driving around Lincoln and Coffin Bay, it also did a good job.
A similar setup could be made using poly tube connected to the garden tap.
Cheers TroySOUTH AUSTRALIA GATEWAY TO THE OUTBACK!
There are lots more places then just above the bash plates that crud gets stuck, i recently made a pressure cleaner of sorts out of a piece of copper tubing with the end bent at 90 degrees and then flattened to give a fanned pressure spay. Placing this through the holes in the chassis rail saw endless amounts of mud pouring out of the drain holes, on top of the fuel tanks is another good spot for crud to hide.
Originally posted by AJ120There are lots more places then just above the bash plates that crud gets stuck, i recently made a pressure cleaner of sorts out of a piece of copper tubing with the end bent at 90 degrees and then flattened to give a fanned pressure spay. Placing this through the holes in the chassis rail saw endless amounts of mud pouring out of the drain holes, on top of the fuel tanks is another good spot for crud to hide.
Cheers Andrew[url=http://www.myswag.org/index.php?topic=12264]My Prado[/url]
Originally posted by D4DOriginally posted by AJ120There are lots more places then just above the bash plates that crud gets stuck, i recently made a pressure cleaner of sorts out of a piece of copper tubing with the end bent at 90 degrees and then flattened to give a fanned pressure spay. Placing this through the holes in the chassis rail saw endless amounts of mud pouring out of the drain holes, on top of the fuel tanks is another good spot for crud to hide.
Cheers AndrewLast edited by AJ120; 21-07-2012, 09:14 AM.[COLOR="#FF0000"]So Long and Thanks for all the Fish![/COLOR]
