Wondering if any one else has had this issue. My R/H indicators arn't working. All bulbs and fuses are fine, and the L/H works properly. When I indicate right, I get one flash and that is it. Any ideas?
Right Hand indicators not working
Re: Right Hand indicators not working
Check the relay for the right had side. Are both front and rear doing the same thing. Not sure if they use one relay or two but it sounds like a relay is sticking.[COLOR=#000080]Nick[/COLOR]
Have looked at all points as recommended, yet no change. Each light on the R/H flashes together as they are supposed too, (including trailer when connected), but only once.
If interested, there is only one flasher unit mounted to the back of the fuse panel under the dash, that both sides use. With the help of a multi meter I have narrowed it down to either the flasher unit or the indicator switch.
Have just finished talking with my local Toyota Workshop, they have heard of this issue after an auto elec fitted an UHF and spliced the power supply from the wrong wire. However this just started out of the blue. They were more than happy to look at it for me, in two weeks. As it is not in warranty, I think I will just order the parts and change them myself.
Thanks for the advise.
