an impact always makes things easy aye
DIY - Brake Pad change (includes pics)
Thank you for the write up. I couldn't see the pics but the instructions were easy to follow.
Pads were easy to pull out and change and noticed a big difference. Local store had Bendix out on special a few weeks ago so did all 4 corners, done in just under 2 hours.
Mark2009 GXL D4D - Auto
[QUOTE=Rusty62;543076
This needs to be put on your regular maintenance program. Remove the rear discs, check pads and handbrake shoes, clean with brake cleaner or water, NO COMPRESSED AIR, re grease the adjuster nuts and reinstall.
Rusty.[/QUOTE]
Possible dumb queston ahead.... why no compressed air Rusty? what's the theory
Haven't done my own brakes in a couple years (Prado won't need for a while yet) but in the past i'd squirt around with the blow gun. what am i doing wrong?
cheers
Originally posted by gxl_d4d View PostHi,
I'm up for front brakes again. I can't track down the front caliper bolt torque specs. If anyone has them or the parts diagram that shows the torque spec can you please post it up.
Thanks,
Click the imgur link, the pic is much bigger and you can read it. It's 123nm btw.2007 GXL V6 - ARB Bullbar with LED lights, snorkel, extractors, 2 1/4" dual exhaust, K&N filter, dimpled/slotted rotors, headrest dvd players, Ebay Satnav/reverse camera, GME 3100TX, Tigerz11 Side awning on custom brackets with Maxtrax mounts, 300W Invertor, ARB Underbody protection, Lightbar and STZ 265/70 tyres.
Originally posted by Hogey66 View PostTorqued to FT on mine. Is it crucial that the anti rattle spring is at the top. Was on the bottom on mine, both sides, so that's the way they went back on.
