Just to add to the stats I thought I would add this one
Stuck on stand dune, applying hand brake to give more traction
In reverse then going forward
Bang
A Strange noise from rear of car.
Takes me back to the HQ Holden
Blown Diff.
I nursed it to the road with help of Leachy, Chippy, and Others.
Rang for a big Yellow truck to tow it away.
Costs so far
Towing……………Free (RAC towing) membership has privileges.
½ day of work lost
ARB Diff Lock IN BOX …………………………………......……$1219.00 with Discount
TO COME
Fixing damaged axles(bent), wheel bearings, Crown and pinion…….......................................... ............................$1700.00
Mounting and buying compressor and switches………………...$500.00
Mine is a 2003 TD out of warranty with 84900km on the clock.
I was told that the axels are bent slightly (8 THOU ) but probably weren’t the cause of the crown wheel giving in and could be straitened.(probably)
Wheel bearings are leaking in water and need replacing as well.
Find out more tomorrow.
Go the lockers
Russ
Bang
Blown Diff.
Costs so far
½ day of work lost
TO COME
Go the lockers
Russ
