Hi,
I recently changed my auto gearbox oil. The check plug has a slight weap as I re-used the old gasket. Can I use fibre washers or the same gasket as is on the engine sump plug or do I need to get a genuine aluminium crush washer?
Also, will thread sealant (non drying type) affect the gear box oil if I use on the last thread of the plugs?
I use this stuff on the driff and transfer drain and fill plugs. It does the job and I don't have to excessively tighten the plugs to get a seal.
Thanks,
Thanks,
