Ok here is the go
1. Clutch is worn...
2. Quoted $900 for valeo kit including fitting plus seals etc..
3. I dont want a HD clutch so as to avoid possible issues with crank thrust bearing a rear diff strain etc...
4. Would you install a valeo clutch or another standard pressure clutch?
Regards
Any advise welcome as its booked in at 0800 tomorrow...I need to cancel and get the right kit in or go with valeo kit....im not towing all that much but im careful with my clutch anyways...
Please no red herring replies or advise on why the planets rotate....just no bullshit replies thanks
Regards
