Trans feels like its holding gear while stationary
  • Trans feels like its holding gear while stationary
    Hey guys
    Only noticed this problem a few months ago, and only happens every now and then.
    When i pull up to a set of lights it feels like the transmission is holding gear and vibrates the vehicle, yet when i put the tranny in neutral or park the vibration disappears.
    Has anyone else had this issue
    any help much appreciated thanks
    Happens every day to me until it is warm, I just whack it into neutral. Obviously it's linked to the engine idle up, when the rpm drops to lower levels when warm it disengages. Not ever having owned an Automatic before this 120 D4D I'm not sure if it's 'normal', but it doesn't seem to be a problem.
    Perhaps others may like to comment on their Auto D4D 120s when cold?
    peril
    2[FONT=Arial Narrow]008 Prado GXL D4D Auto with Prado Pack
    4x4 History: 2000 Prado GXL 90 Series 1KZ-TE, 1992 4runner 2.8 Motson turbo, 1985 Landcruiser 60 Series 3.9L Diesel, 1985 4Runner 2L 2.4 Diesel later mod. + 2.4T (Factory Turbo), 1982 Hilux 2.2L Diesel in Yellow (callsign 'Yellow Peril') later mod. + 2.4L engine[/FONT]
      Doesn't happen to mine but do you use the idle up button?
      [SIZE=1]Cheers Jim.
      [/SIZE][COLOR=#0000cd]
        No I don't mines been disconnected for some reason
          change the gearbox fluid. The torque converter plays up on old fluid. Shudder, shift shock (gear clutch packs) and thump when TC locks up. I think the fluid loses viscosity hence the thumping.
            No, no idel up button used but it grabs at idle until the engine is warm. ie. when the rpms drop by about 100-150rpm from 800 to 650-700rpm. There was no change to this effect even after the fluid was changed in my latest service. Box changes smoothly, no thumping. It changes down in sports mode fine, runs smooth, just a slight grabbing at fast idle when cold.
            peril
              Hi all having same issue with my 08 prado D4D any luck with solutions possible causes?
                Injectors or engine mounts. Engine mounts are a big one for this. There not expensive. My mates (sold his D4D now) but he went through 2 lots of engine mounts plus 2 sets of injectors luckily under warranty, it was due for its 3rd set of injectors when he traded it in, was sick of it and at the time of selling it was out of warranty so was going to cost him a nice penny to replace them. His only did it when it was cold with the injectors, once it warmed up it was fine. Engine mounts it just did it cold or warm. This was his warning when either was due for replacement....Cheers Steve Should say his was an 07 D4D and use to be on here quit a lot at the time
                  Thanks for your reply had mounts replaced 2 months ago I guess injectors are next. Cheers
