Front axles got water inside outside rubber boot 2004 diesel manual
  • Front axles got water inside outside rubber boot 2004 diesel manual
    Morning, Just after some thoughts Both front axles are throwing out small quantities of grey oil consistency droplets from the outside end of the outer boot I suspect water has got in past the boots and mixed with the grease To repair this is a bit of a job and suspect could be pulled apart cleaned in place and repacked with grease although maybe I will have to replace the bearings etc
    But not sure What do others think please?
    Part 2 This is the first time have had what I believe to be an all wheel drive vehicle and wonder if one removes the front driveshaft can one simply drive round like that or will something else happen as a result
    Please also look at the parts wanted section as need rear bumper section for non wide flares model etc
    Flash61,
    As I understand it you would have to engage the centre diff lock to drive around with the front shaft removed.
    Greg - 08 D4D Prado,
      Dear Corigator,
      Thanks mate and as I have this insecurity around the status of the front axle water enhanced bearings ( are they failing or not) I am looking at innovative ways to take the pressure off the bearings till I can make sure the rest of this luffly ex mines vehicle is suitable to drive around your lucky country Gordon Perth
        I probably wouldn't want to drive for too many ks using this method. Others may be able to say if locking the centre diff puts extra strain on it.
