Morning, Just after some thoughts Both front axles are throwing out small quantities of grey oil consistency droplets from the outside end of the outer boot I suspect water has got in past the boots and mixed with the grease To repair this is a bit of a job and suspect could be pulled apart cleaned in place and repacked with grease although maybe I will have to replace the bearings etc
But not sure What do others think please?
Part 2 This is the first time have had what I believe to be an all wheel drive vehicle and wonder if one removes the front driveshaft can one simply drive round like that or will something else happen as a result
Please also look at the parts wanted section as need rear bumper section for non wide flares model etc
