I have a Nov 2004 build Prado with a 6Spd Manual.
The 6Spd box is working perfectly - except that 6th gear has a noise. Its exactly the type of noise you'd expect from a slightly worn diff. With load, the noise gets less or is hardly there. But with slight acceleration or engine de-acceleration (i.e. Cruise ctrl keeping you ticking along at 100 etc), a diff like whine is present.
New Gbox oil will make it quieter for a while. Also, driving around town and not using 6th for a couple of weeks, and then going for a run where you can use 6th always results in 6th being noisier then usual for some time. Then it will quiet down to normal whine levels. Its almost as if it gets quieter when it warms up. I can't explain it but its just enough to annoy me.
I suspect that the 2 6spd gears may have had their hardening worn off? Or it may be a bearing but no one can tell till they take it all out. I've been told that even when it does come out the problem may not be obvious enough and there is a chance that even with a bearing kit and Gear replacement the noise may be still there after its all done.
I want to keep the car for the foreseeable future as its all setup how I like it.
So the options I can see are:
1: Pull the box out, spend the money with the risks as noted above. I also suspect that vehicle down time will be significant as ordering uncommon parts from Toyota will take ages.
2: Find a low Km 6Spd (Wreckers?) replacement box. No idea on cost or how I would find one.
3: Could a 5spd box fit ? Would it be cheaper / easier to find one?
*** All suggestions will be welcome !
