Good Day folks,
i was surfing the net a while ago looking for some lights to change in my car, i found some (seems great for me) lights in www.carid.com .
here is the list i'm planning to get and i want you suggestions and advice. "sorry for the long thread but the specifications are copied from the website"
SilverStar zXe (HeadLights) AUD 60
![](http://www.carid.com/ic/sylvania/car-bulbs/35589_3.jpg)
SilverStar zXe H7 Bulbs by Sylvania®, 1 Pair. 1 pair of high performance halogen bulbs that match OEM dimensions for proper fit and operation. Choose SilverStar zXe halogen bulbs for the look of a HID/xenon bulb with an increase in brightness of 30% and 25% further visibility compared to worn OEM bulbs. 100% street legal.
PlaZma, 70 lumen (1.25" / 32mm / DE3175 Bulb) (Interior Dome Light LED) AUD 13.2
![](http://www.carid.com/ic/lumen/car-bulbs/125-plazma_3.jpg)
PlaZma Series Interior Dome Light Replacement LED Bulb (1.25" / 32mm / DE3175) by Lumen®, 1 Bulb. 1-LED bulb, 70 lumen of light with white color, 180 degree light output. Offers twice the brilliance of standard LEDs using the same power, and features a lifespan 25 times longer than incandescents at a lower operating temperature. Designed to plug into OEM connector without modification. Available in multiple colors.
Lumen® - 18 Watt LED Round Off-Road Driving Light (to be placed above the spare wheel) AUD 58
![](http://www.carid.com/images/lumen/led-off-road-lights/lid-ld-908c-stk.jpg)
Universal 18 Watt LED Round Off-Road Driving Light by Lumen®. 4.5" O.D. This is a single light housing that contains 6 radially-positioned projector beam style LED lights which broadcast cool, white light. Rated for a total of 18 watts, this off-road light is fully resistant to mud and corrosion with an aluminum housing, stainless steel mounting hardware, and a sealed interior that’s water resistant up to 1 meter. 50,000 hours of projected bulb use gives 25 times the lifespan of incandescent bulbs with 1/10th of the energy consumption.
20" Long, 126 Watt (on roof, front side) AUD 264
![](http://www.carid.com/images/lumen/led-off-road-lights/lid-936c-ld.jpg)
20" Long, 126 Watt Dual Row Long LED Light Bar by Lumen®. Pencil beam pattern. Wide rectangular LED light bar measures 20" x 4.25" and contains 42 projector LEDs spaced into two rows. 126 watts of total output, lifespan rated for 50,000 hours. Aluminum housing is fully resistant to mud and corrosion with a sealed interior that’s water resistant up to 1 meter. Built-in heat sink offers improved cooling.
