I have a petrol 120 which has an allrounder main cranking battery, Then through a dual battery isolator, I have a 120a Deep cycle AGM mounted in a drawer system which powers an 80l Waeco. This has been working well for me so far but I have noticed even after driving all day, The rear AGM battery only really gets up to about 12.6-12.8v where as it will go way over 13 when charged by a 240VAC 25a charger. (Cables between batteries are almost welding leads so no issues there) Now I have bought a small van and I was considering running another set of cables from the Prado's rear aux 120a AGM, through an Ando plug to the vans battery which is a 100a AGM. Van has 90l Dometic fridge, led's, pumps etc...My question is Will the alternator be ok to charge all 3 batteries while driving? I have purchased a diode booster hoping it might assist a little and also, is it a problem to have batteries of a different size? Thanks for reading.
How many batteries can I charge?
Originally posted by amts View PostI would also consider having the 2 AGM batteries plugged in occasionally to a 240VAC multi-stage charger to maintain the health of the batteries.
What is your charge voltage at the cranking battery terminals with the motor at 1500RPM and with all batteries fully charged?HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Hi Steve and depending on when you measured the voltage, it sounds like your battery is fully charged.
A fully charged battery, just after the charging source is removed, can have a voltage reading from 12.7v to what ever the charging source was applying, say 13.6v or higher.
This initial voltage reading is seeing the surface charge voltage, something all lead acid batteries have, straight after being charged.
If the battery has a small load on it, like a fridge, it will use up this surface charge fairly quickly and then you will be measuring the battery’s actual voltage.
A fully charged battery, even with a small load, like a compressor fridge, will have a voltage reading of around 12.7v.
The chart below will give an idea of the state of charge of your battery, while it’s in use.
As to how many batteries you can charge, you can actually charge as many batteries as you like.
The more batteries you have, and the lower they are, can slow down how fast you recharge them, but do not try to charge house batteries ( batteries located in a caravan ) and run a 3 way fridge off the same cabling coming from the tow vehicle.
A 3 way fridge’s current draw on any size cabling, will cause so much voltage drop that you will not charge low house batteries properly and in worst cases you can even have a situation where you leave home with full charged house batteries and get to your destination only to find the 3 way fridge has discharged the house batteries while you were driving.
The most effective way to set up a caravan to run a 3 way fridge and charge house batteries at the same time is to run two separate sets of twin power supply cables from the cranker battery to the caravan.
One set of cables will power the fridge and the other set is used to charge the house batteries.
There are other ways to achieve similar results but the two sets of twin cables is the most efficient.
I wonder if there would be a benefit from installing a 2nd isolator and running power to the tug via that.
I'm not sure if there would be any benefit in charging but you essentially have a 2nd circuit from the crank which could be good for other reasons.
TrevCheck out our around Aus adventure on FB at: Cummings and
Goings
Originally posted by LeighW View PostWhat is your charge voltage at the cranking battery terminals with the motor at 1500RPM and with all batteries fully charged?
Originally posted by drivesafe View PostHi Steve and depending on when you measured the voltage, it sounds like your battery is fully charged.
Hi again Steve, your 3 way fridge should not be connected to your batteries in the caravan.
Another solution to the 3 way fridges high 12v current draw is to not run it on 12v at all.
Simply cool the fridge down the night before you travel, then leave it off while you drive.
When you get to where you are going, switch the fridge on, with either gas or 240 mains power.
I have many customers who do this and they don’t have any problems keep food cold, even in t heat of the far north.
Originally posted by drivesafe View PostHi again Steve, your 3 way fridge should not be connected to your batteries in the caravan.
Assuming in van, the absorption fridge with draw around 15A that would would only leave 5 to charge the van battery and having the load connected to the charger is going to upset the mutli stage function. If he is already having a problem with voltage drop, the charger is not going to help it will only be around 70% efficient, and that's at 14.5V input if we drop the voltage down to around 12V then it's going to be drawing a lot more current and unless it is a low voltage model probably won't work. Nothing makes up for under size cabling! Assuming in car with the fridge load your still going to get considerable voltage drop, it will help assuming the output voltage of the charger is higher than that of the alternator, it might not be though. Again nothing makes up for under size cable.Last edited by LeighW; 05-10-2013, 10:48 AM.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
