Led light bar on roof cage
    That bar im getting is 24,000 lumes just for reference
      Could you please post some pictures of your light bar and how you have mounted it??? I am looking to install something similar straight onto a rhino roof rack
        Yeh sure, also is this rail where ive lifted the plastic strip up the right one?
        Does not look like the strip will go back in around window if the wires are in there.
          I cut some 75x10 flat bar and bolted it to the holes in the front of the roof cage and bolted the light bar to that
            Brad there is a channel in the rubber strip that the cable can press into. No need to remove the trim.
              Ok yeh i looked at that and thought i could press it into there with a dab of sikaflex.
              Cheers buddy
              Brad_kosij
                Got it all installed and took it for a drive.. All i can say is Awesome, lights everything up like daylight
                Thanks for the help guys
                Much appreciated
                  Thanks for the pics brad. I aim do do something like this too
