Headlights always on...
  • Headlights always on...
    Hi Gurus,
    I am sick of people letting me know I have my headlights on in the middle of the day and then having to explain its the way I bought it blah blah blah. How do I turn it off/disable it? Cant see a relay or whatever under the bonnet but then again Im no electrical genius either...
    P.S. I have a feeling this car came off a mine...
    Thanks, Nathan
    Hi Nathan
    Have you had a look at the wiring inside the car. Sounds like you could possibly have a headlights on kit plugged into your wiring harness.Here's a link to minecorp and something similar to what you might be looking for. Haven't had any experience with how there wired up so I could be totally wrong you could always email or phone them. Sure they would be able to point you in the right direction
    http://http://www.minecorp.com.au/sites/default/files/u386/pb-0118_toyota_lc70_series_lights_on_kit_rev_a.pdf
    The road less travelled is definitely the best road to be on
      wow thanks shangus, sounds like that might be a goer
        There is a couple threads on disabling the headlights on mine setup vehicles in this forum already I'm pretty sure?
          yeh i guessed so but i cant find them and the pradopoint search button isnt working for me for the moment so...
            Not sure if this link will work http://www.google.com.au/url?sa=t&so...65058239,d.dGI
              have a look under the dash close to the steering column, should be a black box around the size of a deck of cards, may have something like redarc written on it. If you do find one, just disconnect the earth from the chassis and put some electrical tape on it and that should sort it out for you !
              Cheers Joel
