05 Prado starter motor spins but does not engage?
Prado not starting
Starter motor is probably buggered, get it removed and reconditioned or replaced.
I had mine done when it started playing up, it was only $400 to replace, they used a reconditioned one and took mine to recondition for the next one.
Hutch- Prado 150 with some TJM Kit.[b]Rob[/b]
have you removed the starter and checked it out? sounds like the anti reverse function of the clutch may have failed. Pull it off and power it up and see if the pinion engages, if it does, load it up with a piece of wood or the like and see if the pinion stops spinning, if it does the anti revese has failed and you will need to fix that or get a new starter.
Cheers Joel
Originally posted by BarryS View Post05 Prado starter motor spins but does not engage?
Originally posted by BarryS View PostOk, thanks for the tip, as a novice, how do I access it. I suspect the throw gear myself.
You would have to remove the starter motor and grease the outside gear so it freely moves on its axle.Greg - 08 D4D Prado,
Schematic drawing of the 1GRFE starter motor.
http://www.japan-parts.eu/GR/3/191846E.pngSOUTH AUSTRALIA GATEWAY TO THE OUTBACK!
Hello Barrys,
Pull the starter motor out and check that the solenoid contacts are all ok, my Landrover disco 2 had this exact trouble and I was quoted $800 for a new starter. I replaced the solenoid contacts for $23, dry lubricated the sliding gear pinion and the problem was fixed. Contacts last about 120000 km in a LR. This was only one of many problems I had with with the LR.
regards
Ross
