Warning lights!!
  • Warning lights!!
    Hello there,
    good think I found this forum, cuz I've been searching the web desperately for the past two days
    anyway, it's a 2006 V6 VX
    I've the abs, handbrake, engine and the battery lights are always on and sometimes the airbag light too
    Also the speedo is not working and fuel gauge is playing up and down occasionally
    yet with all of that everything works fine
    the issue started last month as my dad was coming back from work
    any suggestion or helpful thought would be appreciated
    thx
    try disconnecting the battery for at least 20mins and see if it resets the ecm???
      This fault is symptomatic of a fault in the charge system, have you checked your charge
      voltage?
      Leigh
        LeighW you r right
        I rest it a week ago but nothing changed
        so today I checked the alternator and it's was charging over 16volts
        odd cuz when I tested it before it was fine
        I'll remove the alternator tomorrow to see what's wrong... probably the rectifier
        Thanks guys
        I'll keep you posted till it's done
          If the voltage is high it will possibly be a faulty voltage regulator in the alternator,
          also check the ALT-S fuse for possible micro cracks etc.
          Leigh
            Yup it was the rectifier
            replaced it with a new one and its good as new
            thanks alot guys
