I want to add a relay in for a custom circuit. Looking around for places to put the relay I came across the little relay box on the side of the main fuse box (Relay Box 3). This relay box houses the Air suspension and Dim Relays. In my 2003 GXL, the air suspension relay is not there and neither is any of the wiring. The Dim relay location has wiring, but no relay.
I have pulled it apart to have a good look at it it is trivial to add the contact into the relay box so I can use the Air SUS relay location for my own purposes.
The problem I have is identifying the part numbers for the terminals that are required to fit into the base of this relay box.
Does anyone know what the part numbers may be or where I can find them. I have tried the service manual with no luck and I am not sure where else to look.
Would like to utilize the DIM relay location one day as well.
Mick
Mick
