Hi all, has anyone got a clue on why all the power windows bar the drivers window intermittently work and dont work from the drivers door switch panel. They all work fine from their respective own door switch locations. When I wiggle the wiring loom at bottom of the drivers door that goes under the dash it sometimes comes good. It seems like a broken wire or two but Im not sure. Has any one else experienced this problem and how to rectify it? Cheers Dave
Intermittent fault in power windows at drivers door switch panel.
I think from memory there's some plugs near the door hindge
or is that what your referring to above, if there are plugs there
try unplugging and replugging them.
Also try the with the door open in various positions if it comes good that
way the cable between the car and the door in the rubber boot might
be fractured.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Originally posted by Scruffy View PostHave you done a relearn yet? They might have lost their memory due to a low voltage issue. I know you said intermittent but if you haven't it is worth a try.Last edited by davelozt; 06-12-2014, 10:42 AM.
Originally posted by LeighW View PostI think from memory there's some plugs near the door hindge
be fractured.Dave
Originally posted by Scruffy View PostDave,
Operate each window in turn fully open to fully closed and keep your finger on the button till you hear a small click at the end of the stroke. Bingo your windows are now all learnt! But it sounds as if you have done it! Just make sure all windows work on auto open and auto close.
Hi all, was just logging on to make an exact same thread when I found this one,
My problem was after having the battery disconnected the rear drivers side window and the front passenger side windows could not be operated from the drivers side panel.
After reading this I 'relearned' all the windows and gained the rear drivers side window back to life but unfortunately no matter how many times I go up and down with the front passenger side I can still only operate it from that side.....what I also find interesting is even operating from the front passenger side, it will not operate in 'auto' like all 4 windows are meant to be able to do (and certainly could before the battery disconection)
So any idea's for this? It was only since the disconection of battery so doubt its any wires broken or plugs coming loose...
1 window to go!
