I saw this idea elsewhere on Pradopoint but with no write up so I thought I would do the repair and document as I go, hope it helps someone as I think the cost of a new centre brake light is over $300. This repair cost me basically nothing and about an hours labour.
1. First remove the centre brake light by getting something thin like a paint scraper and push down from the top to release the 4 plastic tabs and working your way along. This takes a bit of juggling but eventually clips out.
![Click image for larger version
2. Press brake peddle in and test for voltage at the plug, if voltage present then light is faulty.
3. Drill 3 x 20mm holes along bottom of red lense to enable access to inside lense as it is a sealed unit.
4. Cut existing wires and remove rubber grommet from lamp assembly.
5. Insert 300mm 12vdc LED strip light into assembly and poke wires out the cable hole.
next post
next post
