Hi, after some thought i want to run 4 b&s twin cable from main battery to boot and terminate with 175 amp anderson (then just use the 175 into 3 50 amp plugs).
Can the 4 b&s be run inside the cabin easily without being obvious due to its size?
Alternatively i understand theres a grommet somewhere in passenger rear quater panel (but i cant find it) so i can us chassis rail to run cable. Id rather inside thou.
Ps. Its a grande, so not sure if the added electrics will interfere with cable path.
