Hi guys, apologies in advance for long winded post!
I know this is a well discussed topic (I have spent many hours on here looking at Rig Builds and other links) but I was hoping some of you can offer an opinion/suggestion/ pointers on my proposed system I am about to install. Part of the reason is I need to have everything prepared to spend and entire day to install a number of accessories and power supple 'points' with some paid help and 'checks' from a auto sparky too. My proposal is as follows:
Dual Battery system from Traxide (SC80) connecting both batteries via top of radiator (as yet undecided where to mount Sc80) but likely Ill make up a bracket and mount this on top on cranking battery
1 Double sheathed dual 6B&S wire running along chassis rail to single 50A Anderson plug mounted near tow bar and elec brake controller, with 50A circuit breaker near aux batter, and switched using relay and switch mounted in console (all my switches are from air on board).
A second separate line from aux to a LH rear power board with accessory sockets using 6mm twin auto cable via LH side rails in door way. Plan is to install a 4 way fuse block (1 30A for rear power board) and 1 for a Uniden UHF radio and 2 spares for further accessories. This will be mounted near aux using a yet to be made mount utilising existing holes, screws in engine bay.
All relays to be mounted close by too on same or separate custom mounting plate. All wires to be covered with conduit too - however any suggestions on exact or specific cable holders to use in 120 would be helpful to know, or clips etc to piggy back on conduit already installed?
There is currently a separate fused 6mm twin cable powering the RH side (factory spot) rear power socket from the cranking battery. I was going to shift this from main to the aux battery, add a centre console switch and have a 3rd line (or parallel circuit I think is right term). However, I would like to if possible, 'tap' into the 6B&S cable somehow, add a local switch and relay, so I am only running two wires to the rear of the vehicle. I can't find any links on a neat and tidy way to do this so open to suggestions or links, and/or how best to do that.
I also have a traxide low voltage cut off module, however the size of wire (gauge) is smaller in diameter than the wire i plan to use to power rear accessory panel, so I'm not sure how to include this, unless I have this connected next to my accessory panel in the LH rear of vehicle, but a little voltage drop my be a issue? again open to any opinions on this.
Will also add spotlights with relay and switch in console, and as stated the UHF radio too.
I don't have a camper trailer but we plan on hiring one a couple of times in the next 12 months, and will use a 60L Engel fridge occasionally too, so no major long distance touring planned, maybe 2 weeks tops on next 12 months and a couple of week trips here and there.
I have a 115ah century deep cycle battery as Aux, mounted in just installed Offroad Down-under tray.
Any opinions and or help on the above would be appreciated, but my two important questions are:
1. How to tap into the 6B&S cable i plan to run on the chassis to power the RH rear socket, and
2. Anyone have any specific info on mounting the traxide SC80 and low voltage cut out module in the 120 V6 engine bay.
Tim
Tim
