I bought this module from ebay
http://www.ebay.com.au/itm/201537387...%3AMEBIDX%3AIT
Ive installed it today and I highly recommend it for ease of install. Works perfectly. I had it finished in about 45min.
Its RF transmitters, so its bugger all involved.
The stalk bolts in behind the air bag and the transmitter is then cable tied down
The receiver is then soldered onto 1 wire as the signal wire , 1 wire as negative and 1 wire connects to the ignition.
Drill a hole in the bunk for the stalk
and thats it.
Works awesome, cruise light on the dash works, turns off when the brake pedal is pressed.
Does come with the clutch switch if your car is a manual
NOTE: the pic in the ebay ad is a display pic and not the item itself
and thats it.
