Hi,
I recently purchased a 2007 Prado Diesel. I am in the process of setting it up for camping and adding a few things here and there.
It came fitted with a Dual battery system with a 55Ah Battery mounted at the rear of the engine bay (passenger side) with the battery controller and AUX fuse board nearby. Now I want to increase the size of the battery and install a deep cycle battery to help run my Waeco CFX65 for longer. Roughly measuring the battery tray I think there’s max 300mm to play with which is small judging by battery sizes 100ah+.
Is there anything decent that will fit in the tray or should I relocate the battery to the rear of the vehicle?
If I moved it could I leave the controller and fuse board in place under the bonnet and just run a 6 B&S cable fused from the rear battery to supply the controller etc?
Thanks in advance,
Jake![](https://www.pradopoint.com.au/core/images/smilies/icon_smile.gif)
Thanks in advance,
Jake
