Very rough idle in drive d4d 120 2008
    Hi Woody, Suffered the same and had to have r/h engine mount replaced. Fixed most of the vibration but I now have vibration between 1300 to 1600 and not sure what is causing it.
    Regards
    Jon
      Originally posted by pjorek View Post
      could you share the link where you got it from and how much $?
      easy job to a not so handy man?
      careucar.com
      Currently they have the IT2 with Feb 2013 version software for US$320 plus shipping.
      The unit simply plugs into the OBD2 port which is located under the dash in line with your gas pedal so no need to pull anything apart. Data flow function will display all the operating parameters of the engine and other systems.
      Bushbasher
      Out of control poster!
        Hi Jon
        Yeah mate I also have a Vibration (shudder) on the left hand side, well it seems to be on that side anyway, at around the same rpm. I was hoping this would go when I get the problem fixed by Toyota. Another 2 weeks at least till I can get it in to them to have it looked at.
        Regards
        Sean
        2012 BLACK 150 GXL PRADO, ARB DELUXE COLOUR CODED WINCH BAR, REDARC DUAL BATTERIES, 240 BLITZ HID UPGRADE SPOTTIES, 32 INCH LIGHT BAR, LED INTERIOR LIGHTING, HID AND LED HEADLIGHT UPGRADES, CHIP BOX POWER CHIP, 265/70/17 AT BFG, REDARC ELECTIC BRAKES, SCANGAUGE, SAFARI SNORKLE, POLY AIR BAGS, 40 LTR ENGEL, MAXTRAX, RECOVERY POINTS, ARB TOWBAR, TOYOTA ROOF BARS.
          Had Toyota check it out and it turned out to be the engine mounts after all, they replaced both and it fix all the problems straight away.
          Cost was only $450 supplied and fitted.
          Though mine was paid under warranty.
          Regards
          Sean
