Hi guys
I've been having some problems with my car for the past couple months now and its driving me crazy, I hope you guys can help.
I bought my 2005 Prado off my uncle as he wasn't using it and the car was just sitting for a long time not being used. It was driving fine for a week until one day it didn't start; it was cranking but not starting.
I called an auto sparky to come around and have a look. He played around alot and he pretty much stuffed my car up. He played with the ECU and other cables and finally energised the solenoid valve on the fuel pump directly from the battery which was a bad move. The car started but ran very bad. Heaps of smoke, rattling and timing was gone.
In order to fix this problem, I got the fuel pump rebuilt, injectors cleaned, filters changed, head serviced, rings replaced and still its running rough and smoking (the smoke has reduced). According to Toyota theres no ECU fault.
The mechanics are lost and don't know what else to do. He also tried different pumps with no success. It runs rough when cold then bit better when hot but smokes and mechanic said the fuel timing is not correct.
If anyone could help it would be much appreciated.
