Hi
My 1kzte is running slightly rough at idle, particularly when cold and always at idle with the air conditioner running.
There are no error codes using the manual method of checking (bridging on the OBD).
It has new injectors, valves are fine, fuel filter is new, glow plugs new. Air cleaner fine. Has been anti carboned and egr blocked.
Has a 2 3/4" beadesert system.
The thing is it pulls really well so its only at idle that its slightly rough. Given that the air con makes it worse I think its something like a fast idle sensor or something similar. Funny thing is that when the dtronic is fitted it seems to make very little difference to power so maybe they it linked into it somehow. The dtronic is not fitted ATM.
Has me stumped.
cheers
Has me stumped.
cheers
