HUGE Difference in fuel consumption!!!!
  • HUGE Difference in fuel consumption!!!!
    Gday fellas.. im not sure if its a normal thing but ive been noticing a huge difference between the mileage I get from the 1st tank and the 2nd.. roughly highway kms im getting 1000kms on the 1st tank and roughly 650kms on the 2nd?? Has anyone heard of such a thing???
    So you're getting about 1650km from both tanks? i.e. 180L total fuel?
      That's about right.
      I find when 90 light goes on you've used a bit over 90.
      Also if you drive till you run out, you will do 1800-2000k 1kd economy driving.
      But you don't it probably only takes 160-170 ltrs?
        Sound about right, the first tank is 93 litres, the second 87, so 6 Litres difference. Also you never fully use the second tank, it should have 15 litres left when the low fuel light comes on. All sounds normal enough to me.
          Also when the first tank is nearly empty the computer stops moving the needle for about 15lts or so, when you see it flip to the second you've already used some of the fuel already...
          Micheal.
            Also from what iv read the second part of the gauge is ALOT more accurate hence why it empties quicker as its not a true 90L left.
