exhaust mods for diesel 120
  • exhaust mods for diesel 120
    Does anyone know if adding an aftermarket exhaust improves performance for a TB Prado?
    Ando
    05 TD Prado. Dltronic, 55mm lift with King Springs and Bilstein shocks, 15mm rear coil spacers, 285/70/R17 Cooper STT tyres, ARB Deluxe Bullbar, Safari Snorkel, dual battery system, 2 IPF spotties, Roof rack,tow bar
    well my guess would be yes if the replacement pipe is larger and removes some restriction. It also would allow for better combustion as the combustion chamber is scavenged of the spent gases more efficiently allowing for a cleaner dense air charge. There are plenty of exhaust companies around. Taipan is one which comes to mind.
    Steve
    Lightforce 240Blitz driving lights, Rear hitch recovery point, GME tx3400 uhf, 64watt Uni-Solar cell, ARB CKMA12 Air compressor. all awaiting new vehicle to be delivered so they can be remounted.
      Putting in a less restrictive, bigger diameter dump pipe will improve low end performance, allowing the turbo to spool up faster. As suggested Taipan make some good performance exhausts.
      Leachy
      EX-Prado Owner
        Re: exhaust mods for diesel 120
        Does the 1kz-te have a catalytic converter?
        Black 2003, TD, GXL Prado
          I'm hoping it's got a flux capacitor
          [COLOR=#000080]Nick[/COLOR]
            WTF????
              Gold :lol: :lol: :lol: :lol:
              [color=#FF0000]ECB ally bar, IPF HID upgraded, dual battery with CTEK dc to dc inverter, 32lt Engel, Safari snorkel, GME UHF, Maxtrax, bridgstone duelers, Offroad camper Trailer [/color]
              [color=#0040FF]WISH LIST: lift kit, Onboard compressor,recovery points [/color]
                I thought my kids were bad :shock: . Is it something I said ops: ? I am trying to find out whether the old diesel had a CC in the exhaust, I know the D4D does. I supose I can wait until tomorrow and get under there and have a look. Gee..... :lol:
                  That would be a very big NO!!!!!
                    Sorry BB. I saw an oppurtunity and took it.
                      Ha, got ya Nick :twisted: :lol:
                      Thanks to grahmars04 for the sensible and correct answer.
                        I recently fitted the Beaudesert exhaust on my D4D and it has made a massive difference in torque and economy.
                        System consists of a ceramic coated dump off the turbo, hy flow cat and muffler. It is a little noisier than stock but it is well worth the trade off. And you do get a lot stronger diesel exhaust smell mainly due to the smaller cat.
                        I get around 200 kms more fom both tanks. Turbo spools up around 400rpm earlier and doesnt run out of puff at higher RPM. I also run a K+N filter and also found that to work brilliantly, although if i went bush i would change to the original filter for the trip as the K+N does not filter as effectively as the OEM unit.
                        I drove a stocker the other day and couldnt beleive the difference in power levels from just those 2 mods.
                        cheers John
                        2008 GXL Black D4D, 6sp Man. 265/70R17 M/T ATZ4RIB's. MTZ's for play. Kings/EFS 50mm lift. Safari Snorkel. Beaudesert Exhaust, K+N Air Filter. ARB Deluxe bar. GME TX3540. Tekonsha Prodigy . Firestone Airbags. Narva 225's. HID Headlights. Kaymar Spare wheel adaptor.Aero bars. ARB awning. 2010 Jayco OB Swan.
                          That's good to hear John, especially the new fuel economy, will get your money back in no time. :wink:
                            mine will be booked in the next week or 2, minister for fun and finance gave the go ahead so its in for a new 3 inch dump pipe and intermediate muffler and used the std over axle pipe as its already 2.5 inch and mandrel bent, looking foward to it getting done. cheers samo
                              yay, bet your stoked. now you need coerce her into letting you get the chip too :wink:
