diesel rattle in D4D Prado
This is a sticky topic.
    Well, well I traveled north of the state (Tassie) for gravel road rally. Because I had tunes going, I stopped to close a road with tape - oil light flickered. Oh #$%, out in the bush and I didn't even THINK to bring an extra liter of oil with me.
    The 1KD-FTV, has 176K KM's - just had a service with the Toyota Dealer (I bought it used), I did ask them about blowing white smoke on some startups - written on the invoice was the suggestion in the FUTURE that injectors or EGR should be checked out.
    Anyways, guess what? One hell of a rattling noise - but no loss of power, and fuel economy was still OK. Sounds like a petrol engine with a spark plug removed...
    Took it to a non-dealer Toyota specialist - one of the guys pulled the dipstick with it running - and the poor girl promptly sprayed oil out of the dip.
    I'm holding on to some vain hope that it is something simple. I should also point out that there doesn't appear to be oil in the cooliant.
    That's not good news I'm afraid. Mine developed a ticking/rattle with no loss of power etc.
    pulled motor apart to find no1 cylinder scored from the piston. This was due to a blocked oil pick up screen. All relates back to an injector seat failing and allowing blowby to occur.
    I cannot believe that TOYOTA do not accept this is a common fault and a manufacturing defect.
    Bottom line is sounds like a new short motor.
    Hope I am wrong but give me a PM if you need any info as I have just been through this exercise.
    • Come on guys, you've read the threads. It's not common at all for these types of problems with the D4D. Only a handful have failed. (Yeah, right).
      • It is a BIG hand though.
        • Happy Monday from NZ
          Just released from Toyota NZ - 1KD- FTV Injector kits , both Euro 3 and 4 versions avaiable - also includes pipes and washers (both kits are DLC and are NEW injectors not a rebuilt units)
          They are advertised as Hi-lux and are identical to Prado
          I can supply any PP member with these kits
          Cost to you $1700 (AUD at current conversion rates)
          Hope this can help a few of you out of any problems
          Cheers Rick
          07 Prado 120 D4-d
          • Rick are you able to post the part numbers that come in the kit?
            • will obtain all part #'s tomorrow and list both kits
              07 Prado 120 D4-d
              • From Toyota today
                Hilux Injector Kit Euro 3
                2367009330x 4 -injectors
                90430T0008x 5
                237010L010x 1
                237020L010x 1
                237030L010x 1
                2370409015x1
                EURO 4
                2367039316x 4 -Injectors
                9090430013x 5
                2370130060x 1
                2370230060x 1
                2370330060x 1
                2370439055x 1
                This is Injectors, washers, and pipes. The injector orings come fitted to the injectors
                07 Prado 120 D4-d
                • Hi
                  Can anyone tell me why new pipes are required when new injectors are fitted?
                  Are they really necessary?
                  Nik
                  • Injector pipes carry HUGE pressure on common rail systems ( from 15,000psi upwards under load )
                    They are specified as a replacement item (ie non re-useable) once disturbed
                    These pipes MUST be tightened to a set torque to ensure unions (joins) do not fail upon INSTALL
                    I have seen injectors done without fitting new pipes without an issue, but have also seen a failure of a union with massive fuel leakage a few 100 km after install
                    Honestly for the cost - why risk it?
                    Do a job once and do it right !
                    07 Prado 120 D4-d
                    • Oooooh!
                      I will flare-up some back-lash for sure! Lol
                      I am either a genius (highly un-likely) or shear lucky... (Don't think so!) Lol
                      I have personally R&R my high pressure fuel lines "FIVE TIMES" and still no leaks with 160,000km and climbing!
                      Why have you removed your fuel lines so many times you may ask?
                      #1: To fit blanking plate for EGR (Total idiot!.. What was i thinking?).
                      #2: To remove again to drill hole and try again? (Obviously a slow learner?) Lol
                      #3: Penny dropped and removed the plate completely!.. I had enlightenment!! Lol
                      #4: To remove intake manifold to clean it properly and did a compression test whilst easy access to the glow plugs.
                      #5: To fit new fuel injectors and replace the seating washers of course!
                      PS. the word "peace of mined" always reminds me of someone rubbing there hands together with a smile and saying Money, money, money! Lol
                      Also! It is still possible (With knowledge and experiance) to still do the job properly without spending the earth!
                      • Toyota here sent out a bulletin when these 1KD's were new saying replace everytime the come apart
                        This was updated to pipe MUST be replaced if injectors disturbed (ie removed) as the seating face angle changes
                        and OK to reuse if injectors disturbed - which is the bulk of the 1KD issues lol
                        07 Prado 120 D4-d
                        • So Rick what's the go with the deal? For $1700 AUD you will send the whole pack including the pipes and are these the new DLC injectors?
                          • The injectors are new from Toyota NZ - and the kit comes with washers, pipes, and DLC injectors
                            All you need to do is have them fitted and have the new compenstaion codes entered into the ECU
                            The cost is $2050 NZ which at todays exchange rate is $1701.50 AUD -
                            International courier rates vary depending on how fast you want the items
                            1-3 days is $75 NZ
                            3-6 days is $45 NZ
                            I will dispatch the same day as I receive payment and send through a tracking number
                            I am unsure as to your Customs and border controls for taxes (GST and duty) which may be payable at your end
                            for those of you who want to know who I am and what i do ...... search the web for Rick Wheeler Subaru NZ also check out www.bristols.co.nz
                            Send me a personal message - I will need your chassis # for correct kits to be sent and arrange payment and shipping method
                            Looking forward to helping some of you in Aussie stuck with 1KD issues by a very non helpful Toyo AU
                            Regards Rick
                            07 Prado 120 D4-d
                            • Guys, whats the go with the filter between the two fuel tanks. mine has done 110,000 kms and hasnt been changed. toyotas service schedule doesnt include this filter. Should i change it and any idea how much? Dave
                              • Hi again, I have just been reading with great interest the thread on "how many fuel filters"? started back in 2007, as I am trying to get info on my above question. There seems to be great conflict regarding which filter is the main one which needs to be changed every 20,000 kms.(The one under the bonnet or the one between the tanks?) My mechanic, as we speak is sussing it out whilst on the hoist but i would like some feed back from all you knowledgable people out there if possible. Thanks Dave
