diesel rattle in D4D Prado
This is a sticky topic.
  • Injectors have always been considered s consumable part
    No different to tyres and brakes
    There is no set replacement kms, however "normal" use with
    Good fuel does appear to maxing out around the 120-140k mark
    There will be cases of much less and many more k's done
    Feedback / idle volume / mileage and cold start noise are key points to monitor
    07 Prado 120 D4-d
    • Yep cheap insurance spend 2 or 3 grand on it every 5 years or 120k whichever comes first.
      Or save your money for the big popopopopboom!!!!!! WHOOOHAHOOAHAHAAAA.......
        Mine never rattled - ever. Then one day it went BANG.
        Then there are those that only rattled AFTER injectors replaced...
        Micheal.
        • Bought my '07 D4D in January 2015, from a country dealer. One owner, same dealership, etc, etc. 170k on the clock with a full service history.
          Missed the letter from Toyota about injector seats, but started reading this thread last week.
          Rang Toyota about it and they checked the VIN - injector seats not replaced yet, so advised to contact my local dealer. Booked it in for today. They checked the injectors as part of the 'Toyota Process' and advised that ALL injectors were out of spec and required replacement. I told them I had a set of Bailey's blueprinted injectors ready to go and they agreed to fit them at the time they did the seats. Called Bailey's today who have now sent me a set of these injectors - overnighted. Prado booked in for Monday to have them fitted. Dodged a bullet, methinks.
          Stan Miko
          - 2007 120 Series 3.0L D4D
          • Good result stanmiko. See if they will check how blocked the oil pickup screen is while they are at it. If you have to pay for an oil change that is worth it in my view.
              I have seen some 'interesting' pics of clogged up oil pickups. Been looking into this and have just been waiting on a result from Toyota. Gonna try the LIQUI MOLY Engine Detox with the existing oil (changed at 180k service, 3k ago) which is supposed to clear out any sludge and carbon from 'everywhere'. Will also try out some Penrite HPR Diesel 5, which is a 5W40 supposedly to assist with the cold starts.
              Once that is done I will run the tank down to fuel light and start using a product called CRD Fuel Enhancer @ 10mL per 80L.
              Stan Miko
              • Ok, so picked up the Prado.
                Injector readings as follows:
                #1: 0.6
                #2: -2.1
                #3: -2.2
                #4: 3.5
                So, in effect #2, #3 and #4 are FUBAR.
                Quote from Toyota for injectors was $1,936 (Baileys $1,294). They also advised a new fuel filter @ $45.53 and, wait for it... drain, remove and clean out fuel tanks - 3hrs @ $121.00 / hr - total $363.00
                Booked in for next Friday 12th June. Methinks I will be busy with 2 x fuel tanks this weekend... just saying...
                I noticed that they have a separate calendar hanging on their wall for booking these CSE cases in... they allocate 2 x per day and June is already 2/3 taken, with the majority being Hilux's.
                Very interesting...
                Stan Miko
                • Originally posted by stanmiko View Post
                  I don't believe Baileys will allow any form of additive to be used with their injectors.
                  p.s those injector numbers are pretty impressive - but not in a good way!
                  Micheal.
                    I have asked the question... let's see how they respond. I don't see any problem with it, as this additive actually improves the lubricity of the fuel which will retard the wear, as well as reducing corrosion in injectors and pumps. Dosage is just 10mL per 80L fuel.
                    Stan Miko
                      At 36,000 odd KPa - doubt it.
                      • Don't believe everything you read, especially what is printed on the product label. Keep the fuel clean. That is your mission.
                        • Just got my 120 back from Service at our local Tojo dealer - these are my values
                          Val:1/ -2.2
                          Val:2/ +2.1
                          Val:3/ + 0.6
                          Val:4/ -0.7
                          They say these are OK - Can anyone offer their experience here - We are just about to head to the Simpson Desert and I need to fix this OR let it go and relax??
                          Larry D
                          YMUS
                          "[B]The PEARL[/B]" is our early 2009 120 "Pearl White"Grande . [B]The build consists of[/B]: ARB deluxe Bar, Winch is a Domin8tor, Driving lights are 3X Korr LED's. Roof Rack is a RR 42107B. - Rear Draws are from OffRoad Systems 3 draw plus fridge slide, table and 40ltr S.S. tank. See our build site : [URL]http://www.pradopoint.com/showthread.php?32140-Start-of-quot-The-Pearl-quot-transformation-April-2014[/URL]
                          • Do you have total volume too?
                            • Originally posted by YMUS View Post
                              Val:1/ -2.2
                              Val:2/ +2.1
                              Val:3/ + 0.6
                              Val:4/ -0.7
                              Larry D
                              YMUS
                              Going by what I was told with MY readings, I would guess that YOUR #1 & #2 are definitely cactus.
                              If you are replacing two, you might as well replace the lot.
                              Stan Miko
                              • Toyota will tell you that even 2.5 to 3.0 is OK. I was watching my original 2 injectors very closely after my rebuild in 2013. One of them started to move pretty quickly from 2.5 to 2.7 so I ditched all and fitted 4 new ones.
