diesel rattle in D4D Prado
This is a sticky topic.
  • Originally posted by stanmiko View Post
    I have asked the question... let's see how they respond. I don't see any problem with it, as this additive actually improves the lubricity of the fuel which will retard the wear, as well as reducing corrosion in injectors and pumps. Dosage is just 10mL per 80L fuel.
    Did you get a response from Baileys on the use of fuel additives?
    Micheal.
      Page 3 - http://www.baileysdiesel.com/industr...ty-Booklet.pdf
      This Warranty shall not apply to any defect caused by:
      • Repair, alteration or modification carried out by the Customer
      or any third party without written consent from the Company;
      • Accident, abuse or neglect;
      • Normal wear and tear;
      • Product having been used for any purpose other than that for
      which it was designed;
      • The use of any fuel additives/fuel contamination.
      • The use of any non-standard diesel fuel, for example biofuels
      and biodiesel
        CRD Fuel Enhancer @ 10mL per 80L.
        Jeez that's almost homeopathic at that ratio (8000:1).
        The MSDS states ~90% petroleum oil so it can't be from a snake can it??
        • Originally posted by adrian5800 View Post
          A very old snake.
          • Originally posted by Golly View Post
            Only sounds bad when cold, when shes up to operating temp, smooth as a babies bum. Fuel volumes and feedbacks ? sorry, bit of a noob on that question. Can the EGR clean be done by myself ? I am mechanically confident but not tech savy. If I can save 3K I would tackle it myself, just need the how to hahah....
            Bad when cold is not ok.
            Recommend getting the Injectors checked by an expert.
            Read the injector threads & you should learn a bit, search.
            You could start with the link in my signature.
              and biodiesel
              Yeah ive seen that but got the impression the question was specifically asked and a response was coming...
              Micheal.
              • Originally posted by Drosey View Post
                HI guys,
                I need some help here please.
                I have read some very interesting info on this issue regarding injectors and the problems that keep arising with the D4D.
                after talking with Adam (ondaboat) I took my Prado 08 model 84000 ks to Toyota for the rattle on cold start
                It was left there over night for the cold start test and I was told the following.
                Checked at cold start and some rattle evident but not out of ordinary.
                Plugged in scan tool and checked injector values - values as follows
                No1 0.9
                No2 minus 2.1
                No3 4.2
                No4 minus 3.5
                Number 3 and No 4 out of value of minus 3 to plus 3.
                Used car Dept approved to replace 2 injectors if client wants replaced.
                Parts required 2 x injectors (hitech diesel) + 5 hours labour.
                Following parts will be relaced ONLY if required
                Rocker cover gasket x 1 (1121330021)
                Rocker cover injector seals x2 (2368230020)
                Rocker top seals x 2 (2368130010)
                Gaskets x 5 (9090430013)
                My question is should they only replace 2 injectors? Thanks in advance for the feed back,
                Regards
                Hello Guys & Girls.
                How thing have changed in the last two years.
                Dropped the Prado off last night for a service and the "mandatory cold start check of the injector values"
                Just had call from the dealer advising two injectors are out of spec and Toyota reccomend changing all four injectors.
                Then he mentioned that he would ask Toyota to contribute towards the cost ?
                Thats when I said hey what about my extended factory warranty? Oh i will find out was his reply.
                Next minute i was told all good Toyota will pay for all four to be replaced.
                I would like to take this opportunity to thank you all for putting this very important information on this site so people like myself have a good understanding how important it is to get the injectors checked .
                Regards
                • That is a good result, for once.
                  But I would ask for the pipes to be replaced as well. Then check the SCV to make sure it is in spec.
                    Hello Guys & Girls.
                    Regards
                    Definitely replace in sets not 1 or 2, the experts have taught Toyota this, one of many mistakes Toyo dealers did make.
                    hopefully they will follow suit & all do proper injectors tests rather than tell people it will be all ok. Now they just need new software for the egr system.
                    Yes very important information.
                    The big THANK YOU Should be directed to "##########" (diesel & toyota expert) he was the one banging on about it.
                    Others are just repeating what he has taught & that is needed, Jesus has left the building.
                    Many Years ago he contacted me & asked me to get on board, in his words, the people need us. He knew I was a good technician, I was reluctant to get involved with such a big problem, but eventually gave in, somebody has to do it & not many can get it right.
                    So since he got the boot from here, I have been sharing my experiences, helping the people......
                    Not many people out there specialising on Prado & Hilux 1kd motor & focusing on the big problems, then spending the time trying to share.
                    So I am!
                      Happy for you. Once again, Toyota show their inconsistent approach to this issue. When I had engine failure due to 2 going out of spec they would only replace the 2 under warranty. Result is I had to buy and replace 4 injectors a little over 12 months later after the warranty period had expired when the original 2 injectors started to go off. Grrrrrr.
                      • Yep and I still can't get a cold engine test on the injectors as that's 'not necessary' according to the dealer...........wish #### had a double in Sydney........
                        • Originally posted by Riv39 View Post
                          I might be heading north to do some more mobile injector jobs, perhaps I can pop past & do an expert diagnostic for you.
                            Rubbish - Just tell them you want it done. They should do it. Mine did if for me at the 90,000km service.
                            Whereabouts in Sydney?
                            I've got a techstream if you wanted to grab the readings and send to ####.
                            • Just a heads up.
                              Recent cold mornings in Sydney have made my D4D sound like a 2nd world war Russian tractor. Ran the techstream over it & injector #3 is showing -3.0mm3
                              All the others are looking good still & all look perfect when at operating temp. Injectors are roughly 1yr old/<15,000km. Baileys are taking it back for diagnosis in a couple of weeks.
                              Watch this space.
                                Just a heads up.
                                Watch this space.
                                Yet another set of Baileys that has an issue with the injector in pot 3!
                                Baileys know there is a problem, they're keeping a tally...
                                Perhaps Admins we should have a sticky on this titled 'Baileys Injectors issues' or 'Baileys Injector issue with Cylinder 3 after less than 12 months'.
                                Those with Baileys remanufactured injectors in their rigs, keep onto your injector feedback readings, make sure they're done at each service (minimum) - they don't take long to run out 2.9 or 3.0mm3...
                                Micheal.
